Type4 blower assmbly block off plates? |
SKL1 |
May 26 2020, 02:09 PM
Senior Member Group: Members Posts: 1,602 Joined: 19-February 11 From: north Scottsdale Member No.: 12,732 Region Association: Upper MidWest |
I've got some of the block off plates for the sheet metal on the way from bdstone. Does anyone make a good solution for the openings on the front blower assembly if you're not using heat exchangers? Would replace the little flaps.
TIA |
theer |
May 26 2020, 07:21 PM
Senior Member Group: Members Posts: 676 Joined: 31-July 15 From: Dover, MA Member No.: 19,014 Region Association: North East States |
Just bought these from Maddog- they cover all 6 holes in the firewall.
https://maddogsmotorsports.com/914-accessories EDIT: sorry completely misunderstood the question. You may still need these, though, if you take out the heater tubes, etc. up front. |
bdstone914 |
May 26 2020, 08:25 PM
bdstone914 Group: Members Posts: 4,528 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
I've got some of the block off plates for the sheet metal on the way from bdstone. Does anyone make a good solution for the openings on the front blower assembly if you're not using heat exchangers? Would replace the little flaps. TIA Leave they open. Blocking them disrupts the air flow inside of the shroud. If you really want to block them you need to make plates to go onside the fan shroud leading to the ports to the S branches. Under operation with heat exchangers they have air flowing out except when the electric fan creates a higher pressure closing the flaps for more heat at low engine RPM's. |
SKL1 |
May 26 2020, 08:29 PM
Figured if I blocked them off it would allow more cooling air to go to the oil cooler and cylinder fins instead of just out to the atmosphere under the car. I realize if you still have the heating system and it is off it eventually just vents outside anyway but figured anything could help an AC'ed car, especially in Arizona!!!
bdstone914 |
May 27 2020, 06:20 AM
@SKL1
date='May 26 2020, 07:29 PM' post='2819384'] Figured if I blocked them off it would allow more cooling air to go to the oil cooler and cylinder fins instead of just out to the atmosphere under the car. I realize if you still have the heating system and it is off it eventually just vents outside anyway but figured anything could help an AC'ed car, especially in Arizona!!! [/quote] Just blocking them off will have a negative effect on cooling. Think about what happens when air is blown into a blind hole. Do you run an oil temp gauge? It you can hit over 250 under sustained griving you need more oil cooling. |
Lo-Fi Version | Time is now: 29th May 2024 - 03:43 AM |
