wonkipop |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,420 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille ![]() ![]() |
have just dropped gearbox in a 1974 1.8.
to do the clutch. first time - after 46 years. there was this piece of paper on it. probably protected by starter motor. what is it? dusted it carefully. if anything was ever written on it, long faded. mechanic and i think it might be a factory build sticker, like some shelf part thing? dunno. 99.9% sure this gearbox (and engine) have never been dropped before. ![]() ![]() |
davep |
914 Historian ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,159 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada ![]() ![]() |
We may never know what info it had on it. My early 74 built LE had one on it as well. A low mileage car and relatively untouched. Can you measure the dimensions of the label?
wonkipop |
sticker dimensions.
metric (aus is metric like germany). in millimetres. looked at it with a uv light today i borrowed. nothing could be seen. whatever was written on it lost to time. ![]() |
davep |
Thanks. I believe it to be a plain paper label, so exposure to the elements would have eroded the surface quickly thus removing the printing. Mine is in exactly the same location.
IronHillRestorations |
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,732 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None ![]() ![]() |
Is there an aluminum tag under one of the nuts for the side cover? That's what you'll find for a limited slip diff
davep |
Not on mine Perry. Do you have a photo of such a tag?
gms |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,695 Joined: 12-March 04 From: Chicagoland Member No.: 1,785 Region Association: Upper MidWest ![]() ![]() |
rgalla9146 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,570 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None ![]() ![]() |
in situ
Also the trans type would begin with HB.... not HA Attached thumbnail(s) ![]() |
davep |
Great photo Rory.
Lo-Fi Version | Time is now: 16th June 2024 - 10:37 PM |
