| Franky_Four_Fingers |
Jun 28 2020, 10:30 PM
Where is the stoooone? ![]() Group: Members Posts: 19 Joined: 15-April 18 From: Chicago Member No.: 22,041 Region Association: Upper MidWest
I think I'm finally ready to pull the trigger: would prefer something fairly complete. Anyone sitting on a good core?
| mepstein |
Jun 29 2020, 05:28 AM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 21,002 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
I’ll check what’s available at the shop. I do have a complete 3.2 for $8k. Has computer, harness, induction and exhaust. It’s a core that needs a full rebuild.
| Tdskip |
Jun 29 2020, 06:50 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,784 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None
2.7s are great engines if but if you end up looking at one needing a rebuild the 3.2 cores are usually a better way to go.
Jun 29 2020, 06:05 PM
| JmuRiz |
Jun 30 2020, 07:33 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,655 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region
Smart man, 3.2 is a better way to go these days. I got my 2.7 back when core pricing was CHEAP, so it made sense to rebuild it....still cha-ching worthy pricetag.
| mepstein |
Jun 30 2020, 08:20 AM
Smart man, 3.2 is a better way to go these days. I got my 2.7 back when core pricing was CHEAP, so it made sense to rebuild it....still cha-ching worthy pricetag. Yea, they all cost about the same to buy and rebuild. 3.2’s are more initially but 2.7 make up the difference in machining |
| pek771 |
Jul 5 2020, 07:57 PM
Member ![]() ![]() Group: Members Posts: 275 Joined: 23-November 05 From: Conover, NC Member No.: 5,175 Region Association: None
I have a 2.7 which was for the 914 racecar (car is long gone) It needs to come apart because it leaks like a sieve at the #8 Bearing. (I built this engine 10 years ago, and it sat in the basement untouched). Raceware and ARP rod bolts and head studs, all machine work done, JE 9.5:1 pistons special coated, in Alusil cylinders. CR actual is 9.65:1, which will run on pump gas. Single plug. Elgin reground Solex cams. Set up for EFI, no manifolds or EFI stuff included.
$5k OBO, negotiable. Engine is in Florida. |
Lo-Fi Version | Time is now: 20th November 2026 - 09:35 PM |
