| ahycaramba |
Jul 12 2020, 09:44 PM
“I live my life a quarter mile at a time.” ![]() ![]() Group: Members Posts: 161 Joined: 17-March 15 From: Murrieta, California Member No.: 18,534 Region Association: Southern California
It's getting HOT and summer far from over. I'm looking for alternatives to a conventional HVAC system. I like the ideal of electronically run ac and heating system that will not rob power from the engine. I was wanting to know if anyone swapped HVAC system from an electric vehicle? (IMG:style_emoticons/default/idea.gif)
Thanks in advance. |
| hcdmueller |
Jul 12 2020, 10:38 PM
????????????? ![]() ![]() ![]() Group: Members Posts: 542 Joined: 4-February 06 From: UK Member No.: 5,527 Region Association: England
Check out Classic Retrofit. He has a pretty impressive setup for the 911. There was mention of working on a 914 setup, but nothing on the website. Either way, I have seen some pretty good reviews from people on the Pelican Forums.
https://www.classicretrofit.com/collections...ir-conditioning |
| Steve |
Jul 12 2020, 11:25 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,029 Joined: 14-June 03 From: Laguna Niguel, CA Member No.: 822 Region Association: Southern California
Check out Classic Retrofit. He has a pretty impressive setup for the 911. There was mention of working on a 914 setup, but nothing on the website. Either way, I have seen some pretty good reviews from people on the Pelican Forums. https://www.classicretrofit.com/collections...ir-conditioning He does sell the electric compressor by itself. That and a standard condensor in the front trunk and under dash evaporator and you have a complete system. How big is your alternator? The compressor draws 40 amps + condensor fans and evaporator fans, stereo, lights, etc. |
| mgp4591 |
Jul 12 2020, 11:53 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,908 Joined: 1-August 12 From: Salt Lake City Ut Member No.: 14,748 Region Association: Intermountain Region
I've seen mini swamp coolers that are quite small, require about 20oz of water every hour or so and would fit in a corner on the floor, drawing very small amperage from your accessory outlet.
https://www.googleadservices.com/pagead/acl...DhA8&adurl= |
| mepstein |
Jul 13 2020, 05:35 AM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,587 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
Check out Classic Retrofit. He has a pretty impressive setup for the 911. There was mention of working on a 914 setup, but nothing on the website. Either way, I have seen some pretty good reviews from people on the Pelican Forums. https://www.classicretrofit.com/collections...ir-conditioning He does sell the electric compressor by itself. That and a standard condensor in the front trunk and under dash evaporator and you have a complete system. How big is your alternator? The compressor draws 40 amps + condensor fans and evaporator fans, stereo, lights, etc. He sells a custom 911 alternator replacement for $900 that has the juice to power the system. All in, the system is ~$5,500 for a 911. I know they are working on a 914 version but it’s not out yet. They sell as many 911 systems as they can make so the 914 probably isn’t a priority but like Steve said, they sell parts individually. |
| michael7810 |
Jul 13 2020, 06:54 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,082 Joined: 6-June 11 From: Scottsdale, AZ Member No.: 13,164 Region Association: Southwest Region
I’ve used a B-Kool on several 914 Treks during the summer and it works quite well. I drove from Mammoth Lakes to Phoenix in June during record desert temps of 120F coming back from WCR a few years ago and it was not that bad. Tinted windows would have really helped. If I remember correctly I used 125lbs of ice. 20 lbs of ice lasts about an hour and I carried a second ice chest so I only had to buy ice every 2 hours. My only mod was to install a trailer-hitch style connector because a cigarette lighter plug can’t handle a 10 amp load for hours on end.
B-Kool |
| 914e |
Jul 13 2020, 08:48 AM
Member ![]() ![]() Group: Members Posts: 497 Joined: 21-February 20 From: Arizona Member No.: 23,951 Region Association: Southwest Region
It's getting HOT and summer far from over. I'm looking for alternatives to a conventional HVAC system. I like the ideal of electronically run ac and heating system that will not rob power from the engine. I was wanting to know if anyone swapped HVAC system from an electric vehicle? (IMG:style_emoticons/default/idea.gif) Thanks in advance. The compressors from electric vehicles require 200 to 400 volts DC. A new 12 volt compressor can be found about $550, the down side of the low voltage is the current draw is 60 to 70 amps. You will need a high output alternator, something that can produce at least 75 amps at idle. That is typically a 150-200 amp alternator. I would install a higher amp hour battery as well at some point. |
| GregAmy |
Jul 13 2020, 08:52 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,651 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States
Is that the Brit guy doing the electric A/C? He is having his 914 fitted with an EV system on the TV show "Vintage Voltage", fit almost wholly within the Appearance Group center console, looked like a nice setup.
Big spendy dollars though. |
| brant |
Jul 13 2020, 08:59 AM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,167 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains
the stock alternator is what....? 50 amps or is it 35
either way, my concerns with electrical systems is that none of these cars were intended to produce or carry high amp loads overwhelming the electrical wiring is a concern with upgrades I think if you need modern AC and heat then the easiest solution is to buy a modern car |
| SirAndy |
Jul 13 2020, 09:06 AM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,469 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
I like the ideal of electronically run ac and heating system that will not rob power from the engine. That's not how physics works though. A large electrical current draw will still rob power from your engine. (IMG:style_emoticons/default/shades.gif) |
| PanelBilly |
Jul 13 2020, 09:24 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,950 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest
Or move to the PNW. High of 75’ today. Might make 80 this week!
| mepstein |
Jul 13 2020, 09:42 AM
I just noticed an article on their site showing their electric ac in a 912. So it looks like they (or someone) have an alternator that will work with a 4 cylinder engine. They don't currently offer a fresh air blower to fit a 914 but maybe we'll see it soon.
https://www.classicretrofit.com/blogs/news/...th-electric-a-c https://www.classicretrofit.com/collections...wer-for-911-a-c |
| 914e |
Jul 13 2020, 10:19 AM
| SteveL |
Jul 13 2020, 11:01 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 666 Joined: 7-August 03 From: Andover, MN Member No.: 991 Region Association: None
Coolshirt Complete Club System All-In-One Kit
https://competitionmotorsport.com/coolshirt...AyABEgI2XvD_BwE |
| 914_teener |
Jul 13 2020, 03:50 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,270 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
Or move to the PNW. High of 75’ today. Might make 80 this week! We might get down to 75F for a few minutes in late September. Right now you have be out at 4:30 am to enjoy brief few minutes when it dips below 100. I drove from Prescott yesterday and through some strecthes reached 126 through the Sonoran desert. The 6.2 in the Superduty and modern AC was just able to disspate that heat towing our Covid townhome behind us back to Cali. I.d go with the evaporative cooling solution. |
| frostyf |
Jul 13 2020, 05:46 PM
Member ![]() ![]() Group: Members Posts: 155 Joined: 27-March 14 From: VA 23455 Member No.: 17,168 Region Association: MidAtlantic Region
Bit of a branch question from the main Electric topic; has anyone tried an alternate condensor to cutting the frunk floor?? Just wondered if there's scope to mount one in the engine lid (possibly a narrow condensor in a double 914-6 lid) and still isolate it from the hot engine compt air below - or is that just unrealistic??
I'd love to fit one but don't want to cut up the frunk? |
| Steve |
Jul 13 2020, 05:56 PM
The guys in the UK said they could put one in right rear wheel well.
I have not seen it done yet. Since I have a six with a front cooler, I just installed two PMS louvered sections in the front trunk. Easy to do. The oil cooler hot air exits before the condensor. PMS did the same thing in there 916 retro build. |
| mepstein |
Jul 13 2020, 06:21 PM
The guys in the UK said they could put one in right rear wheel well. I have not seen it done yet. Since I have a six with a front cooler, I just installed two PMS louvered sections in the front trunk. Easy to do. The oil cooler hot air exits before the condensor. PMS did the same thing in there 916 retro build. Yea, That's what Jonny told me. Also suggested mounting the electric compressor under the rear trunk, above the right rear axle. He said that should result in no cutting needed. He's a 914 enthusiast but he knows the market is in the 911's. |
| ahycaramba |
Jul 13 2020, 07:03 PM
just incase you are wondering what I'm running it's a WRX EJ20. At the moment I have the car set up without AC and a heater but planning to incorporate that in the future. My alternator output is about 75 amps. I want to make it clean and simple under dash. thinking electrical for both ac & heating but not ruling out conventional HVAC system.
I like all the ideals thus far. (IMG:style_emoticons/default/aktion035.gif) I found this on youtube university. I know it's not a Porsche but it has some useful information about electrical ac system. Check out where he put the ac condenser, WILD! I didn't think it would cool the freon efficiently in that location. https://youtu.be/mRo05wph2F0 Also, Call me crazy for thinking of heating system as well in the middle of summer. What options are there to keeping the cabin toasty in winter other than heat exchangers? Any electrical options out there? |
| frostyf |
Jul 13 2020, 09:32 PM
Mark,
Is Johnny from the classic retrofit outfit in Horsham?? I need to have another look and try to work out what condensor they're using! The guys in the UK said they could put one in right rear wheel well. I have not seen it done yet. Since I have a six with a front cooler, I just installed two PMS louvered sections in the front trunk. Easy to do. The oil cooler hot air exits before the condensor. PMS did the same thing in there 916 retro build. Yea, That's what Jonny told me. Also suggested mounting the electric compressor under the rear trunk, above the right rear axle. He said that should result in no cutting needed. He's a 914 enthusiast but he knows the market is in the 911's. |
Lo-Fi Version | Time is now: 2nd April 2026 - 04:37 PM |
