| macnichol |
Oct 15 2020, 08:12 PM
Newbie ![]() Group: Members Posts: 40 Joined: 12-June 20 From: Indianapolis, IN Member No.: 24,372 Region Association: NineFourteenerVille |
I pulled the oil metal mesh basket today and I was a little panicked to see that it looked like this. The metal center where the the bolt goes thru looks deformed to me, is that normal? The mesh itself I had to crush a bit removing from the metal plate and I used a new one. I'm praying that the previous owner did *not* over torque that bolt, how can I tell if this is the case? Also, how do you guys remove rounded bolts? The oil drain plug is near impossible to get off with the state it's in right now.
| Superhawk996 |
Oct 16 2020, 06:10 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,573 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
I've seen worse strainers. Count it as a blessing as long as you're not finding metal trash on the strainer.
Not sure how bad your oil drain plug is but here are a couple options least invasive to most invasive 1) Heat the case around the bolt with a propane touch 1st. This will expand the aluminum faster than the steel and help loosen it before you try to turn it with existing standard socket or maybe vice grips. 2) Rounded bolt socket extractor https://www.acmetools.com/shop/tools/gearwr...tchFacets=true# 3) Slot the drain plug with a die grinder cut off wheel. Use impact screwdriver with widest blade you can get to loosen it. Alternatively, you might just use a ratchet drive type screwdriver head. https://www.mscdirect.com/browse/tnpla/8387...AiABEgJwLfD_BwE 4) Drill out with left hand drill bit. Hope it loosens while drilling the shank out progressively larger. If it doesn't, finish drill it and helicoil it. Lots of extra work to keep swarf out of case. (IMG:style_emoticons/default/sad.gif) |
| Cairo94507 |
Oct 16 2020, 06:16 AM
Michael ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,511 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California
I just removed a rounded drain-plug last night on my son's car - not a Porsche - after he had previously taken the car to a quick oil change place and they rounded the drain-plug off. I used a good quality pair of vice grips clamped on very tightly and tapped the plug with a small hammer and then it came loose. Got lucky IMHO. (IMG:style_emoticons/default/beerchug.gif)
| 914Sixer |
Oct 16 2020, 06:42 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,356 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region
Screen looks normal. I think I may have a few NOS filter nuts and screens, have to look. Added pictures of NOS one
| barefoot |
Oct 16 2020, 06:48 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,440 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States
Be careful that the screen center is not deformed upward. When building my engine, it would not build oil pressure, the center had blocked the oil pick- up tube, fixed that then OK.
Lo-Fi Version | Time is now: 7th December 2025 - 05:55 PM |
