WTB: 2.0 Exhaust, Monza Style 2.0 Exhaust |
MFejsa |
Oct 21 2020, 04:24 AM
Newbie Group: Members Posts: 40 Joined: 25-April 20 From: Saudi Arabia Member No.: 24,178 Region Association: None |
Superhawk996 |
Oct 21 2020, 03:24 PM
914 Guru Group: Members Posts: 5,875 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Wow - a teener in Saudi Arabia. (IMG:style_emoticons/default/welcome.png)
Shipping of a Monza muffler will not be cheap. Those are pretty heavy. Username @MB911 makes some great stainless steel mufflers to forever end muffler rust through. You can likely patch what you have. As you probably know, it will be a temporary solution. Best case is find someone good at TIG welding and they can patch it and it will hold you for a couple years until it rusts out somewhere else. I had a Monza that was heavily patched and repaired before it had to be junked. Just recently obtained a set of used, really rusty 914/6 pipes that needed a new collector transition fabricated for use as test pipes. TIG welded it up OK but it won't last forever until the next rust through. |
MFejsa |
Oct 22 2020, 03:34 AM
Thanks for the post. I actually managed to buy a set of stainless steel ones from Mark at Werks last night. I believe shipping will be around $200 so was expecting some added expense to get it here but at least they will last and will be a better option to that of monzas
I believe its the only 914 in Saudi too so will get some onlookers Cant wait to get it finished and on the road. Its not a runner yet and need some work done to get it started. |
Lo-Fi Version | Time is now: 1st June 2024 - 02:23 AM |
