FS Headlight Installation Hardware kits |
bdstone914 |
Oct 25 2020, 09:38 AM
bdstone914 Group: Members Posts: 4,533 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
I have assembled two different kits for headlight installation.
The A Kit includes: (6) 4mm SS allan head socket screws and washers to attach the ring to the headlight frame. The original phillips head screws are prone to stripping out the heads. The allan heads allow more secure installation to prevent them from dropping down the bucket. The washers distribute the load on the tab for less distortion. (6) 4.2 mm SS oval head screws to attach the cover to the frame. (6) 4.2 mm SS flat head countersunk screws to attach the headlight surrounds. Cost $12.50 shipped. The Kit B includes all of the above and (10) 4.2 zinc plated Tinnerman clips. cost $17.50 shipped. Each kit is enough to do both headlights. The picture shows 12 clips but only 10 are needed and included. several kits available now and will be offered ongoing Kit C will be for the installation of the headlight pivot brackets with (4) new yellow zinc plated plates 6mm allan head screws, hardened flat washers, and star washers. I am short on the washers and bolts but they are on order. Price is $30 for kit C. Or $25 if ordered with any other kit. Attached thumbnail(s) |
DRPHIL914 |
May 3 2021, 07:35 AM
Dr. Phil Group: Members Posts: 5,768 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
I have assembled two different kits for headlight installation. The A Kit includes: (6) 4mm SS allan head socket screws and washers to attach the ring to the headlight frame. The original phillips head screws are prone to stripping out the heads. The allan heads allow more secure installation to prevent them from dropping down the bucket. The washers distribute the load on the tab for less distortion. (6) 4.2 mm SS oval head screws to attach the cover to the frame. (6) 4.2 mm SS flat head countersunk screws to attach the headlight surrounds. Cost $12.50 shipped. The Kit B includes all of the above and (10) 4.2 zinc plated Tinnerman clips. cost $17.50 shipped. Each kit is enough to do both headlights. The picture shows 12 clips but only 10 are needed and included. several kits available now and will be offered ongoing Kit C will be for the installation of the headlight pivot brackets with (4) new yellow zinc plated plates 6mm allan head screws, hardened flat washers, and star washers. I am short on the washers and bolts but they are on order. Price is $30 for kit C. Or $25 if ordered with any other kit. @bdstone914 Bruce, do you have any of these full kits in stock? also do you have the pivot brackets? Phil |
bdstone914 |
May 3 2021, 08:01 AM
I have assembled two different kits for headlight installation. The A Kit includes: (6) 4mm SS allan head socket screws and washers to attach the ring to the headlight frame. The original phillips head screws are prone to stripping out the heads. The allan heads allow more secure installation to prevent them from dropping down the bucket. The washers distribute the load on the tab for less distortion. (6) 4.2 mm SS oval head screws to attach the cover to the frame. (6) 4.2 mm SS flat head countersunk screws to attach the headlight surrounds. Cost $12.50 shipped. The Kit B includes all of the above and (10) 4.2 zinc plated Tinnerman clips. cost $17.50 shipped. Each kit is enough to do both headlights. The picture shows 12 clips but only 10 are needed and included. several kits available now and will be offered ongoing Kit C will be for the installation of the headlight pivot brackets with (4) new yellow zinc plated plates 6mm allan head screws, hardened flat washers, and star washers. I am short on the washers and bolts but they are on order. Price is $30 for kit C. Or $25 if ordered with any other kit. @bdstone914 Bruce, do you have any of these full kits in stock? Phil @DRPHIL914 Yes, which kit? A, B, or C ? |
DRPHIL914 |
May 3 2021, 08:08 AM
I have assembled two different kits for headlight installation. The A Kit includes: (6) 4mm SS allan head socket screws and washers to attach the ring to the headlight frame. The original phillips head screws are prone to stripping out the heads. The allan heads allow more secure installation to prevent them from dropping down the bucket. The washers distribute the load on the tab for less distortion. (6) 4.2 mm SS oval head screws to attach the cover to the frame. (6) 4.2 mm SS flat head countersunk screws to attach the headlight surrounds. Cost $12.50 shipped. The Kit B includes all of the above and (10) 4.2 zinc plated Tinnerman clips. cost $17.50 shipped. Each kit is enough to do both headlights. The picture shows 12 clips but only 10 are needed and included. several kits available now and will be offered ongoing Kit C will be for the installation of the headlight pivot brackets with (4) new yellow zinc plated plates 6mm allan head screws, hardened flat washers, and star washers. I am short on the washers and bolts but they are on order. Price is $30 for kit C. Or $25 if ordered with any other kit. @bdstone914 Bruce, do you have any of these full kits in stock? Phil @DRPHIL914 Yes, which kit? A, B, or C ? C - full kit, - the parts that have the pivot arm and bushing shaft , do you have those too? |
DRPHIL914 |
May 3 2021, 08:09 AM
these
T.Rick6 |
May 10 2021, 07:57 AM
Member Group: Members Posts: 51 Joined: 1-October 19 From: Douglasville, Ga Member No.: 23,512 Region Association: South East States |
I'll take Kit B & C please, Thanks for doing these (IMG:style_emoticons/default/beerchug.gif) Todd
Shivers |
May 10 2021, 09:37 AM
Senior Member Group: Members Posts: 2,411 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
Wow, very nice! So much time saved for so little cash.
Luke M |
May 10 2021, 09:41 AM
Senior Member Group: Members Posts: 1,375 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States |
Hi Bruce,
I'd like 2 of the B kits please. I'll pm you later today. Looking for a few other items as well. Thanks. |
56kabrio |
May 10 2021, 02:08 PM
Member Group: Members Posts: 54 Joined: 1-December 05 From: Nashville, TN Member No.: 5,219 Region Association: None |
Bruce
I would like to get both a B and C kit please. Thanks Mack |
56kabrio |
May 10 2021, 02:21 PM
Double post.
Sorry . |
frostyf |
May 10 2021, 09:32 PM
Member Group: Members Posts: 153 Joined: 27-March 14 From: VA 23455 Member No.: 17,168 Region Association: MidAtlantic Region |
Bruce, can I buy a kit C please :
Kit C will be for the installation of the headlight pivot brackets with (4) new yellow zinc plated plates 6mm allan head screws, hardened flat washers, and star washers. I am short on the washers and bolts but they are on order. Price is $30 for kit C. Or $25 if ordered with any other kit. Can I check payment email for paypal? |
Lo-Fi Version | Time is now: 3rd June 2024 - 03:55 AM |
