| oakdalecurtis |
Feb 21 2021, 06:50 PM
Oakdalecurtis ![]() ![]() ![]() Group: Members Posts: 1,426 Joined: 5-June 15 From: Oakdale, Ca Member No.: 18,802 Region Association: Central California
Just curious, have 76 2.0, stock except for Crane Fireball EE, runs flawlessly, just had valves done. I had cleaned the throttle body a few years ago, just noticed, while air cleaner was off, a good layer of soot on throttle plate and inside throttle body. Is this indicative of anything?
| Tom_T |
Feb 21 2021, 06:54 PM
TMI.... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,321 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California
Just curious, have 76 2.0, stock except for Crane Fireball EE, runs flawlessly, just had valves done. I had cleaned the throttle body a few years ago, just noticed, while air cleaner was off, a good layer of soot on throttle plate and inside throttle body. Is this indicative of anything? Probably running too rich Curtis. Check that your aux cold start valve (5th injector) &/or that the other 4 injectors aren't running too rich. Check the plugs for carbon build-up too. Cheers! (IMG:style_emoticons/default/beerchug.gif) Tom /////// |
| JamesM |
Feb 22 2021, 09:26 PM
Caretaker of 914s - Master of Fuel Injection ![]() ![]() ![]() ![]() Group: Members Posts: 2,320 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
Just curious, have 76 2.0, stock except for Crane Fireball EE, runs flawlessly, just had valves done. I had cleaned the throttle body a few years ago, just noticed, while air cleaner was off, a good layer of soot on throttle plate and inside throttle body. Is this indicative of anything? 75-76 cars the crank case vents into the air box just before the throttle plate so oil vapor, blow by gasses, etc are all getting sucked through the throttle body. Cant say for sure if that is what is going on, but I wouldn't expect the throttle plate to clean and shiny on the late cars. |
| Tom_T |
Feb 23 2021, 01:17 PM
Just curious, have 76 2.0, stock except for Crane Fireball EE, runs flawlessly, just had valves done. I had cleaned the throttle body a few years ago, just noticed, while air cleaner was off, a good layer of soot on throttle plate and inside throttle body. Is this indicative of anything? 75-76 cars the crank case vents into the air box just before the throttle plate so oil vapor, blow by gasses, etc are all getting sucked through the throttle body. Cant say for sure if that is what is going on, but I wouldn't expect the throttle plate to clean and shiny on the late cars. A good point to add to our telecon last night Curtis. (IMG:style_emoticons/default/beerchug.gif) Tom /////// |
| Mark Henry |
Feb 23 2021, 01:24 PM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
Just curious, have 76 2.0, stock except for Crane Fireball EE, runs flawlessly, just had valves done. I had cleaned the throttle body a few years ago, just noticed, while air cleaner was off, a good layer of soot on throttle plate and inside throttle body. Is this indicative of anything? 75-76 cars the crank case vents into the air box just before the throttle plate so oil vapor, blow by gasses, etc are all getting sucked through the throttle body. Cant say for sure if that is what is going on, but I wouldn't expect the throttle plate to clean and shiny on the late cars. Weber carbs get what's called "carbon tracing lines" on the butterflies when you have worn throttle shaft bushings. |
Lo-Fi Version | Time is now: 4th October 2026 - 11:19 PM |
