FS early steering column assembly, complete assembly |
rgalla9146 |
Mar 8 2021, 12:00 PM
Advanced Member Group: Members Posts: 4,569 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
For sale
Early 914 4cyl steering column assembly. Includes 2 keys, ignition lock, ignition switch, directional switch and horn contact ring. Both keys work, one appears to be the companion valet key. Looks to be in working condition, not disassembled. $125. plus shipping Attached thumbnail(s) |
BillJ |
Mar 8 2021, 12:38 PM
Senior Member Group: Members Posts: 1,111 Joined: 4-March 13 From: charlotte, NC Member No.: 15,610 Region Association: None |
JeffBowlsby |
Mar 8 2021, 03:19 PM
914 Wiring Harnesses Group: Members Posts: 8,533 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
"early" is not precise enough. What's important is the multipin connector 12 pin or 14 pin (13 really, one is blank)?
rgalla9146 |
Mar 8 2021, 04:29 PM
JeffBowlsby |
Mar 8 2021, 05:51 PM
"early" is not precise enough. What's important is the multipin connector 12 pin or 14 pin (13 really, one is blank)? Thanks for the help Jeff, it is a 12 pin connector. Would the appearance of lock change if it was a 14 pin ? I think the locks are the same |
messick |
Mar 8 2021, 06:11 PM
Newbie Group: Members Posts: 39 Joined: 15-June 20 From: Orange, CA Member No.: 24,381 Region Association: Southern California |
For sale Early 914 4cyl steering column assembly. Includes 2 keys, ignition lock, ignition switch, directional switch and horn contact ring. Both keys work, one appears to be the companion valet key. Looks to be in working condition, not disassembled. $125. plus shipping PM Sent. |
rgalla9146 |
Mar 8 2021, 09:42 PM
B2524 |
Mar 9 2021, 01:50 PM
It's a sickness. Group: Members Posts: 72 Joined: 12-November 11 From: Outside Paso Robles CA Member No.: 13,776 Region Association: Northern California |
2nd if the deal falls thru.
Looking for same thing with keys. |
Lo-Fi Version | Time is now: 9th June 2024 - 05:17 PM |
