> rust and metal repair and replacement panels, current list
dr914@autoatlanta.com
post Mar 11 2021, 10:57 AM
As 914s become more popular, the values going WAY up, and owners holding on to the great cars, new entrants into ownership are having to deal with rougher cars to restore. As many of you know my slogan when I first started reproducing the panels in 1984 was "if you have no body, you have no car". and that proceeded me on my way to make many many repair panels to keep the 9114 on the road. Here is a list of everything we make:
b914503031b fender dog leg left
b914503032b fender dog leg right
b91450303111a fender to cowl repair left
b91450303211a fender tio cowl repair right
b914531005a left lower door skin
b914531006a right lower door skin
B91450108910 left sill plate with two supports
B91450109010 right sill plate with two supports
B91450101310 left inner rocker panel
B91450101410 right inner rocker panel
B91450312510 left outer rocker panel
B91450312610 right outer rocker panel
B91450143410A right longitudinal upper
B91450143410B right lower longitudinal
B91450115310 jack post
B91450115110 jack post support
B91450194420C right inner wheelhouse
B91450158710 battery tray
B914503908gt gt steel flare set of four
B91450390310DJ left door jamb
B91450390410DJ right door jamb
B91450164315 left inner firewall
B91450164415 right inner firewall
B91450111920a left outer firewall
B91450111920a right inner firewall
B91450394310 left sail panel
B91450394310 right sail panel
B91450143612 914 engine shelf
B91450182510 engine bay c channel
B914503903DC door catch reinforcement
B91450704110 left floor pan triangle
B91450704210 right floor pan triangle
B91450110910 left floor pan crossmember
B91450111010 right floor pan crossmember
B91450108320 rear trunk floor
b91450107510 914 emergency brake handle stand
B91450103010 rear trunk hinge cup bracket
B91450104411 right rear suspension console
b91461801310 control unit bracket
b91460201100 914-6 control unit bracket
B91451219110 trunk hinge bolt
if you need anything they are easily ordered from our website, and if you need advice as to exactly which part you need to repair your 914, do not hesitate to send pictures or call and send pictures. We can give you some good guidance as how to repair. 914s are simple cars and therefore not too difficult to restore perfectly. Best thing is that at the end, you will have a great driving dependable sports car!
- Lo-Fi Version Time is now: 12th July 2025 - 12:07 PM
