engine lid grill retainers, how to remove |
EJP914 |
Mar 24 2021, 08:30 AM
Member Group: Members Posts: 260 Joined: 14-June 03 From: Monroeville, PA Member No.: 821 |
Looking to repaint my engine cover grill and the two side grills. Do the rubber covered speed nuts(?)that hold the grills in place twist off or do you have to pry them off? How to do it without scratching the surrounding paint. Thanks for the advice.
EJP914 |
cary |
Mar 24 2021, 09:05 AM
Advanced Member Group: Members Posts: 3,900 Joined: 26-January 04 From: Sherwood Oregon Member No.: 1,608 Region Association: Pacific Northwest |
This is what I'm using.
https://www.gearwrench.com/gearwrench-41840...-plier-set.html Get behind the edge and pull straight down. |
iankarr |
Mar 24 2021, 09:19 AM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,481 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
(IMG:style_emoticons/default/agree.gif) And if you don't have those, just muscle em with a linesman plier (carefully). You'll prob need to replace them anyway.
Here's a link to the lid resto video... https://www.youtube.com/watch?v=H5B108S6DvA |
914Sixer |
Mar 24 2021, 04:58 PM
914 Guru Group: Members Posts: 8,906 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Tack puller from Ace Hardware about $4 .
Attached image(s) |
rhodyguy |
Mar 24 2021, 05:02 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,093 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Don't damage the pins getting that last 1/32".
914werke |
Mar 24 2021, 05:04 PM
"I got blisters on me fingers" Group: Members Posts: 10,140 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
If your trying ot save the plastic letters good luck.
I used a dremel with a small diamond blade & cut off the push-on fasteners that do have a embedded metal clip in them |
VegasRacer |
Mar 24 2021, 09:43 PM
ELVIRA Group: Benefactors Posts: 8,524 Joined: 27-March 03 From: Between Scylla and Charybdis Member No.: 481 Region Association: None |
Sacrifice the clips. (IMG:style_emoticons/default/sawzall-smiley.gif) Save the letters. (IMG:style_emoticons/default/cheer.gif)
Lo-Fi Version | Time is now: 9th June 2024 - 02:58 PM |
