| Mark Henry |
Apr 1 2021, 09:20 PM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
I don't usually show customers cars but member Warren914 from Halifax nova Scotia has a 1975 914 that will be an interesting project. His teen has never run right in the 20 years he's owned it so it's in for a full engine restoration.
His 914 arrived from Halifax this week and at first glance it's nothing special, tired paint with lots of chips and dents. But a quick check shows it has little to no filler in the body. Warren told me this crazy story about the PO being a aircraft mechanic for CP Air, a now defunct Canadian airline. Yeah-yeah what ever dude (IMG:style_emoticons/default/rolleyes.gif) Attached image(s)
| Mark Henry |
Apr 1 2021, 09:27 PM
First order was to get the rockers off, which turned a 3 hour job because the PO used windshield urethane to glue them on. We found the jack posts were rotted so they'll need to be replaced....but the rest of the long was in surprisingly good shape.
Hmmm... Attached image(s)
| JeffBowlsby |
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,236 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None
Explain the CS bit Mr. Henry.
| Mark Henry |
Apr 1 2021, 09:31 PM
Typical couple pounds of sand that comes out of rockers that haven't been cleaned in over 20 years.
| Mark Henry |
Apr 1 2021, 09:32 PM
Explain the CS bit Mr. Henry. All in good time grasshopper. (IMG:style_emoticons/default/biggrin.gif) |
| Mark Henry |
Apr 1 2021, 09:37 PM
So we started to drop the engine and transmission....what a freaking greasy mess!
| Mark Henry |
Apr 1 2021, 09:41 PM
| Mark Henry |
Apr 1 2021, 09:44 PM
What the fuch???
| Mark Henry |
Apr 1 2021, 09:52 PM
So no this isn't a creamsicle... but it has a creamsicle suspension.
Actually it has a Canadian Pacific Air (CP Air) inspired suspension, orange and white was CP Air's colours and the PO obviously painted it at work. I think it's powder coat, which 20-30 years ago was still a relatively new paint technique. Warren914 wants to keep the colour even though it's not "correct" so I'm going to get the bottom of the teen dry ice blasted. |
| Mark Henry |
Apr 1 2021, 09:59 PM
Ohhh and the jack posts are bad so the longs must be boned right?
And WTF is going on with the floors, WTH is it with all these bolts in the floors???? It must be a rusty bondo bucket right? Attached image(s)
| Mark Henry |
Apr 1 2021, 10:01 PM
| VegasRacer |
Apr 1 2021, 10:16 PM
ELVIRA ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 8,933 Joined: 27-March 03 From: Between Scylla and Charybdis Member No.: 481 Region Association: None
| Mark Henry |
Apr 1 2021, 10:26 PM
I think all the bolts are some sort of aircraft reinforcement, I bet you could jack from the middle of the floor. They have long strips of metal running under the bolts, looks like about 1/16" material. I don't think there's any rust issues besides the jack posts, but again we'll have to wait to see as I'm trying to figure all this out myself. All the body gaps a perfect.
So I'll update this in a week or so once we get it dry ice blasted. Warren's car won't be correct, but it's looking like it will be super solid and once fixed up, it should be a real nice teen. Did you notice the Bilstein shocks? I bet the fronts are billy bobs as well. Yes I lied about it being a creamsicle...but it is for sure a diamond in the rough. |
| Warren914 |
Apr 2 2021, 06:43 AM
Member ![]() ![]() Group: Members Posts: 93 Joined: 26-February 21 From: Nova Scotia Member No.: 25,265 Region Association: Canada |
So no this isn't a creamsicle... but it has a creamsicle suspension. Actually it has a Canadian Pacific Air (CP Air) inspired suspension, orange and white was CP Air's colours and the PO obviously painted it at work. I think it's powder coat, which 20-30 years ago was still a relatively new paint technique. Warren914 wants to keep the colour even though it's not "correct" so I'm going to get the bottom of the teen dry ice blasted. Take good care of my car! The car wasn't red from the factory. PO did an almost complete color change. Inside the doors is red, around the fuel tank, engine bay, and even under the carpets. There's only one place where the original color may still be in place. It's well hidden... I was told the white was used on landing gear of the aircraft. Trunk hinges, engine, transmission, and many other small parts have been plated. Don't know where the orange originated. Restoring the car to concourse is not practical. I'm not going through a full color change again, removing rear reflector, and so on. Can't explain the bolts in the floor. I didn't think anything of it given that they are fully sealed in the undercoating. It seemed original factory. This summer's project is the drivetrain and other minor repair. I'm hoping it gets home in time to enjoy before snow flies. Next year the car will get dents and dings removed and a new coat of paint. The windshield has to be replaced. I have OEM front and rear valences to attach, center caps for the wheels, etc. |
| Mark Henry |
Apr 2 2021, 07:27 AM
| ValcoOscar |
Apr 2 2021, 07:45 AM
Garage Life ![]() ![]() ![]() ![]() Group: Members Posts: 2,608 Joined: 19-November 13 From: SoCal Member No.: 16,669 Region Association: Southern California
Same here (IMG:style_emoticons/default/welcome.png)
I'm looking forward to the transformation. Keep the photos coming. Once done, I have a special 914 Care Package for you two. Here is a teaser photo O (IMG:style_emoticons/default/popcorn[1].gif) (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/popcorn[1].gif) (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/popcorn[1].gif) |
| Mark Henry |
Apr 2 2021, 08:16 AM
It won't be done this time around, it will still need paint and new seat covers, but at least it will be driveable.
I imagine I should I do the jack post repairs after the dry ice? |
| Mark Henry |
Apr 2 2021, 08:35 AM
The car wasn't red from the factory. PO did an almost complete color change. Inside the doors is red, around the fuel tank, engine bay, and even under the carpets. There's only one place where the original color may still be in place. It's well hidden... It was a silver car, wasn't hard the Karmann tag says L97A, I also checked in a hidden area as well. It's more than you think Warren, the PO disassembled the whole car to paint it red, longs are red and under the dash is red with zero over spray. Funny thing is it's a BC car, a colour change but real in good shape structurally and mechanically (except for the engine) that's has sat in storage for years and eventually it traveled east. That's almost the exact same story as my 914. . |
| mepstein |
Apr 2 2021, 09:03 AM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,630 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
The floor bolts are really strange.
| Mark Henry |
Apr 2 2021, 10:03 AM
Lo-Fi Version | Time is now: 15th April 2026 - 06:04 PM |
