Master Cylinder Switch |
partwerks |
Apr 4 2021, 08:31 PM
Senior Member Group: Members Posts: 1,593 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
Would the Master Cylinder Warning switch be the same as on the clutch master cylinder?
rjames |
Apr 4 2021, 08:39 PM
I'm made of metal Group: Members Posts: 3,961 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
partwerks |
Apr 4 2021, 09:11 PM
Would the Master Cylinder Warning switch be the same as on the clutch master cylinder? Unless you’re car has been modded, your car doesn’t have a clutch master cylinder. Are you looking for a replacement switch? If yes, I may have one for you. It's been modified. I think the brand name is Wilwood? |
rjames |
Apr 5 2021, 10:34 AM
Would the Master Cylinder Warning switch be the same as on the clutch master cylinder? Unless you’re car has been modded, your car doesn’t have a clutch master cylinder. Are you looking for a replacement switch? If yes, I may have one for you. It's been modified. I think the brand name is Wilwood? Short of someone having an answer for you here, I'd contact Summit Racing. |
Lo-Fi Version | Time is now: 11th June 2024 - 08:59 PM |
