914Rubber Manual Throttle, Question about forward guide bracket… |
jim_hoyland |
May 16 2021, 09:07 PM
Get that VIN ? Group: Members Posts: 9,314 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
How does the guide-bracket mount ? There’s a hole for the screw and a “nub” facing upward. Is a hole needed to accommodate that nub on the bracket ?
I assume the nub is to prevent the bracket from misaligning the rod… I’m missing that bracket (IMG:style_emoticons/default/sad.gif) @Mikey914 |
rgalla9146 |
May 17 2021, 04:12 AM
Advanced Member Group: Members Posts: 4,564 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
How does the guide-bracket mount ? There’s a hole for the screw and a “nub” facing upward. Is a hole needed to accommodate that nub on the bracket ? I assume the nub is to prevent the bracket from misaligning the rod… I’m missing that bracket (IMG:style_emoticons/default/sad.gif) @Mikey914 I'm pretty sure every chassis has the hole /slot that the small bracket/hanger attaches to....on the top surface of the tunnel near the gas pedal Attached thumbnail(s) |
mb911 |
May 17 2021, 05:37 AM
914 Guru Group: Members Posts: 6,872 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
They do. I put one on. Please note the rubber snubber at the end falls off easily. I need to find a replacement. Probably should be glued on
Mikey914 |
May 17 2021, 05:39 AM
The rubber man Group: Members Posts: 12,677 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
You are correct there is a hactory hole in the chassis.
jim_hoyland |
May 17 2021, 08:07 AM
Thanks for the pic; the problem has been resolved…..
Lo-Fi Version | Time is now: 3rd June 2024 - 05:45 AM |
