WTB or Borrow 75-76 Exhaust Manifold |
bkrantz |
May 28 2021, 09:57 PM
914 Guru Group: Members Posts: 7,803 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
I need one exhaust pipe from a 75 or 76 2 liter to lend to a machinist while he repairs an exhaust stud. I need just one side, and only the section that bolts to the cylinder head.
bdstone914 |
May 29 2021, 07:58 AM
bdstone914 Group: Members Posts: 4,537 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
I need one exhaust pipe from a 75 or 76 2 liter to lend to a machinist while he repairs an exhaust stud. I need just one side, and only the section that bolts to the cylinder head. @bkrantz I should have one. I also have single head exchanger ends that i have used as a drill guide to locate the hole for the head stud. It you have ine good stud that shoukd work. The 75-76 have a bigger loop for the stud that may not be as accurate. Found one Attached thumbnail(s) |
bkrantz |
May 29 2021, 10:00 PM
I need one exhaust pipe from a 75 or 76 2 liter to lend to a machinist while he repairs an exhaust stud. I need just one side, and only the section that bolts to the cylinder head. @bkrantz I should have one. I also have single head exchanger ends that i have used as a drill guide to locate the hole for the head stud. It you have ine good stud that shoukd work. The 75-76 have a bigger loop for the stud that may not be as accurate. Found one @bdstone914 that would be great. Please let me know if you have one I can buy or borrow. |
bdstone914 |
May 29 2021, 10:03 PM
I need one exhaust pipe from a 75 or 76 2 liter to lend to a machinist while he repairs an exhaust stud. I need just one side, and only the section that bolts to the cylinder head. @bkrantz I should have one. I also have single head exchanger ends that i have used as a drill guide to locate the hole for the head stud. It you have ine good stud that shoukd work. The 75-76 have a bigger loop for the stud that may not be as accurate. Found one @bdstone914 that would be great. Please let me know if you have one I can buy or borrow. You can have it for $10 and cost of shipping. Attached thumbnail(s) |
bkrantz |
May 30 2021, 08:38 PM
I need one exhaust pipe from a 75 or 76 2 liter to lend to a machinist while he repairs an exhaust stud. I need just one side, and only the section that bolts to the cylinder head. @bkrantz I should have one. I also have single head exchanger ends that i have used as a drill guide to locate the hole for the head stud. It you have ine good stud that shoukd work. The 75-76 have a bigger loop for the stud that may not be as accurate. Found one @bdstone914 that would be great. Please let me know if you have one I can buy or borrow. You can have it for $10 and cost of shipping. Thanks @bdstone914 . I may have come up with a better option. If not, I will contact you. |
Lo-Fi Version | Time is now: 9th June 2024 - 04:25 PM |
