914 2.0 Litre Distributor, Advice Needed |
Clubsport32 |
Oct 16 2021, 02:24 PM
Newbie Group: Members Posts: 7 Joined: 21-January 20 From: United Kingdom Member No.: 23,849 Region Association: None |
Hi All,
After some advice please on a distributor. I am process of restoring a 1973 2.0 litre, GA engine code and I am unsure whether I have the correct distributor. It is brand new, but I think it’s from a type 4.. (it came with the engine..) The number on the side of the dizzy is 0231 172 019. And I believe the correct distributor is 0231 174 009 for a 1973 2.0 litre… My questions are; Implications of running the 172 019 dizzy in my car? What do I need to change to make it correct - eg same spec as the 174 009.. Any suggestions, advice would be appreciated. Thanks Andy Attached thumbnail(s) |
davep |
Oct 17 2021, 10:54 AM
914 Historian Group: Benefactors Posts: 5,154 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
Will you be running carbs or the original FI? Far better distributors are available than that one for a 914.
JeffBowlsby |
Oct 17 2021, 12:57 PM
914 Wiring Harnesses Group: Members Posts: 8,535 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
73 2.0L dizz is PN: 039905205
It accommodates the trigger points for the FI |
Lo-Fi Version | Time is now: 11th June 2024 - 03:25 AM |
