914 oil cooler bracket issues |
rcarson25 |
Oct 25 2021, 09:17 AM
Member Group: Members Posts: 62 Joined: 15-May 17 From: TN Member No.: 21,103 Region Association: South East States |
Trying to install my new oil cooler on my 2.0 4 motor. The bracket that goes on the side of the cooler opposite the studs is not fitting my oil cooler. Is that bracket needed? Does it provide mounting support or can it be left off?
Attached image(s) |
bdstone914 |
Oct 25 2021, 10:06 AM
bdstone914 Group: Members Posts: 4,539 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Trying to install my new oil cooler on my 2.0 4 motor. The bracket that goes on the side of the cooler opposite the studs is not fitting my oil cooler. Is that bracket needed? Does it provide mounting support or can it be left off? Yes it is needed. Do you have a new Dansk cooler ? I had to file down the flanges on the cooler to make the bracket fit. Can you show a picture of the problem ? |
914werke |
Oct 25 2021, 10:59 AM
"I got blisters on me fingers" Group: Members Posts: 10,146 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
It will not "slide" on the end of the cooler it must be clamped on
rcarson25 |
Oct 25 2021, 11:21 AM
The oil cooler appears to be about 1/8” too wide to fit the bracket when orientated the way it is supposed to go.
Attached image(s) |
rcarson25 |
Oct 25 2021, 11:36 AM
Also, can #5 in the diagram be added later or does that go behind the oil cooler on the short stud?
Attached image(s) |
Jack Standz |
Oct 25 2021, 02:40 PM
Member Group: Members Posts: 287 Joined: 15-November 19 From: Happy Place (& surrounding area) Member No.: 23,644 Region Association: None |
My most recent motor rebuild needed a new oil cooler. Same problem. Oil cooler a little large for the bracket.
Fixed quickly with a Drexel to the aluminum that was in the way. |
rcarson25 |
Oct 25 2021, 04:33 PM
My most recent motor rebuild needed a new oil cooler. Same problem. Oil cooler a little large for the bracket. Fixed quickly with a Drexel to the aluminum that was in the way. Yeah that was my next route. Wanted to make sure there wasn’t something I was missing first. |
bkrantz |
Oct 25 2021, 08:34 PM
914 Guru Group: Members Posts: 7,807 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
Check out my build thread. I fixed this recently by trimming the edges of the cooler "sides" with a sharp utility knife.
Lo-Fi Version | Time is now: 11th June 2024 - 07:37 PM |
