Posts in this area are restricted to the following format. If you have a general question, please post it in the Garage.
1. All new threads MUST be titled with a part number only. (i.e. 901.351.801.17)
2. Thread description should be an english description of the part. (i.e. Brake Dust Shields)
3. Replies to the thread are only restricted by pertinence. Some examples are original finish of the part (painted, cad plated, etc), common failures (cracking at the mount points), repair information or tips, pictures (stock or custom), upgrades, etc.
If you have any questions regarding the rules of this forum, please PM McMark.
> Is there a source for this rubber vacuum "Y"?
jrmdir
post Nov 1 2021, 11:40 AM
Connects the AAR to the plenum on my '73 1.7. Small branch feeds vacuum to the Decel Valve. PET shows something similar as 022-129-637 B and that seems to be available from several sources (see: http://www.914world.com/bbs2/index.php?showtopic=227136) But on that version the right angle of the larger tube won't work with how the AAR is situated relative to the plenum on the 1.7.
TIA for any suggestions.
Ron
eric9144
post Nov 1 2021, 12:15 PM
(IMG:style_emoticons/default/beerchug.gif) Think this is what you're looking for? Shape of yours is a bit odd but...
https://914rubber.com/branch-piece-air-dist...with-fittings-1
eric9144
post Nov 1 2021, 12:32 PM
**actually this link:
https://914rubber.com/split-y-aar-valve-1
- Lo-Fi Version Time is now: 1st July 2025 - 08:00 AM
