how do I get this out?, dash removal |
hndyhrr |
Nov 7 2021, 06:10 PM
Senior Member Group: Members Posts: 555 Joined: 1-September 13 From: central point,oregon Member No.: 16,332 Region Association: Pacific Northwest |
I am taking out the dash. How do I get this undone? See pic. Attached thumbnail(s) |
hndyhrr |
Nov 7 2021, 06:14 PM
I am taking out the dash. How do I get this undone? See pic. here it is from the inside Attached thumbnail(s) |
partwerks |
Nov 7 2021, 06:16 PM
Senior Member Group: Members Posts: 1,593 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
hndyhrr |
Nov 7 2021, 06:19 PM
partwerks |
Nov 7 2021, 06:24 PM
I am taking out the dash. How do I get this undone? See pic. It almost looks like you would slide it to the left, and push back up through?? tried to slide but would not budge, perhaps some gentle persuasion? Try warming it up a bit with a heat gun to see if that helps it to slide? |
hndyhrr |
Nov 7 2021, 07:45 PM
got it out, one more thing albeit little is done.! |
partwerks |
Nov 7 2021, 07:49 PM
I am taking out the dash. How do I get this undone? See pic. It almost looks like you would slide it to the left, and push back up through?? tried to slide but would not budge, perhaps some gentle persuasion? Try warming it up a bit with a heat gun to see if that helps it to slide? Can't see the back side, but doesn't appear there are slots on the back side, so maybe slide it to the left, and then poke the back of it through first, and then those tabs might slip up into those slots?? |
hndyhrr |
Nov 7 2021, 08:29 PM
I am taking out the dash. How do I get this undone? See pic. It almost looks like you would slide it to the left, and push back up through?? tried to slide but would not budge, perhaps some gentle persuasion? Try warming it up a bit with a heat gun to see if that helps it to slide? Can't see the back side, but doesn't appear there are slots on the back side, so maybe slide it to the left, and then poke the back of it through first, and then those tabs might slip up into those slots?? it did slide to the left and then just jumped right up and out. don't have heat gun used very gentle leftward persuasion. |
partwerks |
Nov 7 2021, 08:30 PM
I am taking out the dash. How do I get this undone? See pic. It almost looks like you would slide it to the left, and push back up through?? tried to slide but would not budge, perhaps some gentle persuasion? Try warming it up a bit with a heat gun to see if that helps it to slide? Can't see the back side, but doesn't appear there are slots on the back side, so maybe slide it to the left, and then poke the back of it through first, and then those tabs might slip up into those slots?? it did slide to the left and then just jumped right up and out. don't have heat gun used very gentle leftward persuasion. Good job! |
Lo-Fi Version | Time is now: 10th June 2024 - 08:19 AM |
