> Windshield wiper woes
914werke
post Apr 19 2022, 05:27 PM
So, Ill preface this with a short story.
Customer brought a car to me for Fuel line update. A process that includes the removal of the tank ... All went well & the car went back together & outside to get a bath prior to PU. After its wash hop in to move it, hit the wipers that creak to life, sweep .5 way across the windshield ...& stop.
(IMG:style_emoticons/default/dry.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/hissyfit.gif)
So this is a cautionary tale to suggest if you've never serviced you Windshield wiper assembly, you might consider it.
Those of you in the warmer climes probably are less concerned but here in the PNW their function is pretty important, if you drive your car.
The design of the cowl lends itself to allowing water to get into the shafts & of course rust to follow.
Even rusted they may work ... albeit slowly. The motor laboring to grind the shafts in the bushed collars until... either the motor gives it up or they just seize.
Like this customer's car. (IMG:style_emoticons/default/headbang.gif)
Motor is fine, the shafts rusted to the point they no longer will turn.
emerygt350
post Apr 19 2022, 07:35 PM
Thanks for the warning. I know I will be under there this summer and will definitely lube up the joints.
r_towle
post Apr 19 2022, 07:57 PM
Custom Member
Cautionary tale, never wash a 914 with water.
914Sixer
post Apr 20 2022, 06:15 AM
Yep, 50 yr old white grease has dried up. Getting like the rest of us, old and slow. (IMG:style_emoticons/default/biggrin.gif)
StarBear
post Apr 20 2022, 09:03 AM
QUOTE(914Sixer @ Apr 20 2022, 08:15 AM) *
And (partially) dried up. (IMG:style_emoticons/default/dry.gif)
914werke
post Apr 20 2022, 10:02 AM
So ... one side of the the offending assembly
The shaft & collar separated from the linkage assy (for pictures)
The hidden ugliness (IMG:style_emoticons/default/sad.gif)
What the compromised shafts do to the collars overtime (the other side was worse)
what the collars are supposed to look like
(IMG:style_emoticons/default/rolleyes.gif)
Root_Werks
post Apr 20 2022, 12:26 PM
Village Idiot
Textured!
914werke
post Apr 20 2022, 12:43 PM
Patina ~
porschetub
post Apr 20 2022, 08:33 PM
QUOTE(Root_Werks @ Apr 21 2022, 06:26 AM) *
Wow those shafts are bad,combined with a tired motor with gummed up grease in the gearcase its a wonder the fuse didn't blow ??.
Haynes manual mentions 3.5 amps on full speed.
jsaum
post Apr 21 2022, 06:32 PM
My wipers just quit working a few weeks ago I’ll soon be doing the same thing! And while I’m in there I’ll fix the not working fresh air blower motor, fun times ahead!
Root_Werks
post Apr 22 2022, 09:45 AM
Village Idiot
@914werke
Rich, can you post some pics of the fix? What do you do? Sand smooth as best as possible, grease and good to go or get new shafts bushings etc.?
914werke
post Apr 22 2022, 10:08 AM
Pretty much find a new rack.
I had a couple of (lrg) tubs of racks and tore apart maybe 8 or 9 to find 2 or 3 that were still in good shape. The shafts have to have a fairly tight tolerance in the bushed collars otherwise the wipers will wobble exacerbating the problem.
The other challenge is that racks were not designed for ease of rebuilding / re-bushing.
What I did in figuring out how to "rebuild" them was grind off the peened swivels from the shafts then drill & tap those (what I call) swivels so I could reattach good shafts.
Ultimately a LOT of work. better off finding a rack that is still not worn/rusted to sh*t.
Root_Werks
post Apr 22 2022, 10:18 AM
Village Idiot
Oh crap! Glad more than ever mine work and feel tight. That is a lot of work.
914werke
post Apr 26 2022, 05:56 PM
BTW this is what a shaft is supposed to look like
jsaum
post Apr 27 2022, 03:52 PM
Any good tips on how to get a rusted one apart? I have a spare assembly from a parts car, I got one side off but the other is pretty rusted and won’t budge. I have it in the sonic cleaner now if that doesn’t work I’ll try soaking it over night in Evapo rust.
NARP74
post Apr 27 2022, 04:24 PM
Good advice there, keep your shafts lubed as they get older. Need to be in working order in case the need should arise.
Root_Werks
post Apr 27 2022, 09:34 PM
Village Idiot
QUOTE(NARP74 @ Apr 27 2022, 03:24 PM) *
I like this thread, never had to take a 914 unit apart. Not a light task!
- Lo-Fi Version Time is now: 23rd September 2025 - 12:15 AM
