What are the differences between a 2.0 VW and 914 motor? |
DBF |
Jul 1 2022, 10:19 PM
Member Group: Members Posts: 92 Joined: 29-August 21 From: Wisconsin Member No.: 25,865 Region Association: Upper MidWest |
I have a 76 VW van and a 74 914, both with 2.0 Type 4 motors. I have been searching the internet, without much luck, trying to find out what modifications Porsche did to the internals of the VW Type 4 motor to bump horsepower from 67 to 95, and torque from 101 to 119. I see the heads are different. It also looks like they both used dished mahle pistons, with the Porsche having a 7.6 compression ratio, and the VW a 7.3 compression ratio. Anyone know what else was modified such as camshaft specs, crankshaft, etc. Thanks.
era vulgaris |
Jul 2 2022, 05:45 AM
J is for Genius Group: Members Posts: 982 Joined: 10-November 13 From: Raleigh, NC Member No.: 16,629 Region Association: South East States |
The bus pistons have a larger dish, which I've read is part of what gives them the lower compression ratio
914Sixer |
Jul 2 2022, 06:05 AM
914 Guru Group: Members Posts: 8,902 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Jake Raby covered all the information you need to know in depth. He developed a engine kit specifically for the VW Bus to maximize horsepower for it. Check Type 4 store for kit information.
bdstone914 |
Jul 2 2022, 07:05 AM
bdstone914 Group: Members Posts: 4,534 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
The bus motor has hydraulic lifters with a different csm and has a lower red line.
TheCabinetmaker |
Jul 2 2022, 07:45 AM
I drive my car everyday Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
2L bus has 1.8 heads and valves, lower compression, deep dished pistons. Not a true 2L.
nathanxnathan |
Jul 3 2022, 10:07 AM
Member Group: Members Posts: 291 Joined: 16-February 18 From: Laguna Beach, CA Member No.: 21,899 Region Association: Southern California |
They're all 1971 cc — not really 2 liters (IMG:style_emoticons/default/poke.gif)
Here's a chart from the old tunacan site |
Montreal914 |
Jul 3 2022, 10:50 AM
Senior Member Group: Members Posts: 1,582 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California |
If I recall, the 76 912E had L-Jet. Table says D-Jet... (IMG:style_emoticons/default/confused24.gif)
nathanxnathan |
Jul 3 2022, 05:53 PM
If I recall, the 76 912E had L-Jet. Table says D-Jet... (IMG:style_emoticons/default/confused24.gif) I think you're right, Wikipedia confirms it. Trying to verify that, I came across a thread on 912bbs.org saying that 912e engines didn't have numbers stamped on the block, and the number on the fans shroud started in "406" and not 2 letters. I don';t have much experience with 912's to know for sure. |
wonkipop |
Jul 3 2022, 06:14 PM
Advanced Member Group: Members Posts: 4,396 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille |
If I recall, the 76 912E had L-Jet. Table says D-Jet... (IMG:style_emoticons/default/confused24.gif) I think you're right, Wikipedia confirms it. Trying to verify that, I came across a thread on 912bbs.org saying that 912e engines didn't have numbers stamped on the block, and the number on the fans shroud started in "406" and not 2 letters. I don';t have much experience with 912's to know for sure. 912E is L jet. bus motor is more or less a bored out 1.8 as @TheCabinetmaker says. its all about torque. its a truck engine (thats not an insult - just what it is). the 914 2 is a porsche re-engineered VW engine. i think Hans Mezger did the design work on it? EDIT maybe the most interesting engine of them all is the least known. 1.8 AN engine for europe only. 8.6:1 compression ratio and 85 hp. pumping out nearly the same as the USA 2.0 L from 75 on. but carbies and no emissions gear and a taste for high octane fuel. if they had stuck L jet on that i reckon they might have pulled 90 hp out of it. but it would have required its own tuned L jet system = more research development $ they didn't have budget for? |
Lo-Fi Version | Time is now: 6th June 2024 - 11:19 AM |
