Dropping engine |
Dropping engine |
914-Kazoo |
Jul 16 2022, 06:19 AM
Newbie Group: Members Posts: 45 Joined: 19-August 20 From: Kalamazoo, MI Member No.: 24,609 Region Association: Upper MidWest |
I'm planning on dropping the engine out of my 1974 2.0 liter 914. I've got my car on a BackYard Buddy drive on lift. I have a concern that the clearances between the ramps could interfere with engine removal.
Does anyone know the measurements across the engine? Thanks for the help. |
mepstein |
Jul 16 2022, 07:50 AM
914-6 GT in waiting Group: Members Posts: 19,312 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
A lot of times you need to angle the engine so the engine tin clears everything. Not hard.
mgphoto |
Jul 16 2022, 11:22 AM
"If there is a mistake it will find me" Group: Members Posts: 1,339 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
Factory manual says the body should be 27 inches off the ground, remove air cleaner and auxiliary heater fan if it’s there, might help to remove the rear valance.
GBX0073 |
Jul 16 2022, 12:33 PM
Member Group: Members Posts: 164 Joined: 21-December 20 From: Illinois Member No.: 25,007 Region Association: Upper MidWest |
+1 remove the rear valance
NARP74 |
Jul 16 2022, 02:35 PM
Senior Member Group: Members Posts: 1,073 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains |
I think he is talking width, not height.
914-Kazoo |
Jul 16 2022, 05:22 PM
rgalla9146 |
Jul 16 2022, 06:15 PM
Advanced Member Group: Members Posts: 4,568 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Measure the width of the cast iron engine support.
I think that's the widest part. Also, If you're lifting the body above the engine the tire ramps will be free to be moved away. |
bkrantz |
Jul 16 2022, 09:03 PM
914 Guru Group: Members Posts: 7,801 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
If you remove the cross bar, the widest dimension will be across the front corners of the sheet metal. You can measure this from the top, in the engine compartment.
davep |
Jul 16 2022, 09:28 PM
914 Historian Group: Benefactors Posts: 5,152 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
Here is one really good trick. I have done a lot of single handed engine drops with just a trolley jack, and the rear of the car on jack-stands or ramps. Get some sheet metal or similar material about 6" wide and a couple of feet long. These are fitted between the engine tin and the inner suspension consoles when the pivot shafts with nuts on the end interfere with the engine tin as it drops. The sheet metal helps to guide the engine tin over the ends of the nuts making for a smooth drop.
Amphicar770 |
Jul 17 2022, 05:54 PM
Senior Member Group: Members Posts: 1,196 Joined: 20-April 10 From: PA, USA Member No.: 11,639 Region Association: MidAtlantic Region |
I ran into this issue with my 4-post lift. Here is what I had to do.
http://www.914world.com/bbs2/index.php?sho...=274995&hl= When putting it back in, the tangerine racing plate attached to a transmission jack was a huge help. |
914-Kazoo |
Jul 25 2022, 07:26 PM
I ran into this issue with my 4-post lift. Here is what I had to do. http://www.914world.com/bbs2/index.php?sho...=274995&hl= When putting it back in, the tangerine racing plate attached to a transmission jack was a huge help. Amphicar770, thank you for the suggestions. I've got 37" clearance between rails so the tin does not clear. So would you suggest removing tranaxle first then drop engine onto lift cart spin cart and then lift car to clear engine? Thanks again for your help. |
VaccaRabite |
Jul 26 2022, 08:38 AM
En Garde! Group: Admin Posts: 13,465 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Take it off the lift/ramps and use a jack and jackstands.
If it does not clear your lift, you are going to make it a LOT harder then it is if you try to separate the transmission. Its 4 bolts and lower if you keep it as one unit. It is NOT hard to do using a jack and jackstands. Zach |
Superhawk996 |
Jul 26 2022, 09:39 AM
914 Guru Group: Members Posts: 5,891 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
It is NOT hard to do using a jack and jackstands. Zach (IMG:style_emoticons/default/agree.gif) Even easier if you happen to have the Tangerine Racing lift plate. Back in the 80's, I spent years dropping the engine with nothing more than a K-mart socket set, two jackstands, an Allen Wrench for the shift coupler, a pair of Vice-Grips, and a tiny K-mart 2-ton hydraulic jack. Given the thread started 10 days ago, the engine could have been in and out 10 times by now. This is a case where nice equipment is making a job harder than it needs to be. |
914-Kazoo |
Jul 30 2022, 07:26 PM
Thanks for the replies, your right I'm overthinking this. Got everything apart except for the last 4 bolts, rolled off the lift and will finish the removal once I receive my freshly ordered Tangerine lift plate.
Thanks to everyone for your help with my first engine/trans drop. |
ChrisFoley |
Jul 31 2022, 04:41 AM
I am Tangerine Racing Group: Members Posts: 7,934 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Hi Malcolm.
Not sure why the USPS couldn't deliver it Friday. Tracking shows that it was in Grand Rapids by Thursday morning. |
Lo-Fi Version | Time is now: 6th June 2024 - 08:16 AM |
