> Dip Stick snapped off in Oil tank
G e o r g e
post Aug 17 2022, 07:07 PM
Dr
Hello,
I have been away for too long, anyhow I noticed a puddle of oil under car, pulled dip stick out put it back in , pulled it out and the last part of the Stick was gone. must have been 50 years of metal fatigue. Question is whats it going to take to get it out of the tank?
it is a /6 tank
George
post Aug 17 2022, 07:15 PM
914-6 GT in waiting
You can’t try a magnetic retrieval tool. They are a couple dollars at flaps.
G e o r g e
post Aug 17 2022, 07:23 PM
Dr
QUOTE(mepstein @ Aug 17 2022, 06:15 PM) *
that was my thought, figured I would pick it up in the middle and pull off magnet as I pulled it back out.
I will have to give it some attempts.
bkrantz
post Aug 17 2022, 07:36 PM
How long a piece broke off?
mb911
QUOTE(G e o r g e @ Aug 17 2022, 05:23 PM) *
Probably pull the tank and clean out anyway.
porschetub
post Aug 17 2022, 09:51 PM
QUOTE(mb911 @ Aug 18 2022, 01:36 PM) *
Now that is a crappy thing to happen (IMG:style_emoticons/default/headbang.gif) ,best to remove the tank filler pipe assembly as the broken piece could be stuck in there or it has fallen into the tank so Ben's answer is the only way to go,its a PITA but cleaning the tank is a good thing to do anyway .
Lots of crap can build up in the lowest point of the tank and cause corrosion ,my factory tank had been repaired in that area and was pleased to see it was done very well.
Good luck.
post Aug 18 2022, 05:41 AM
914-6 GT in waiting
On the other hand, it doesn’t hurt anything. I’ve seen plenty of 911 oil tanks with pieces of dip sticks in them. It doesn’t go anywhere.
Rob-O
post Aug 18 2022, 08:46 AM
Doesn’t the factory tank have a brazed in screen about halfway down the tank? I thought I remember this ring the case. If so it shouldn’t makes it’s way to the filter console or pick up. Just remember the screen is there if fishing with a magnet. You don’t want to push that magnet and break the screen. Again, if I’m remembering correctly the screen seemed fragile.
michael7810
post Aug 19 2022, 08:04 AM
From what I've read a magnet wont stick to the dipstick.
Root_Werks
post Aug 19 2022, 10:29 AM
Village Idiot
QUOTE(mepstein @ Aug 18 2022, 04:41 AM) *
If you can't get the piece out, shouldn't hurt anything.
rgalla9146
post Aug 19 2022, 11:55 AM
The dipstick tube extends down through the screen.
There are magnets that have long spring-like extensions.
Take the filler neck off and aim the magnet through the hole in the screen. The line of
sight might be too difficult in the car but worth a try.
You might have to lay across the trunk lid to get a good view.
- Lo-Fi Version Time is now: 10th November 2026 - 09:05 PM
