911.106.033.00, Hub extension Complete Black - 914-6 |
Posts in this area are restricted to the following format. If you have a general question, please post it in the Garage.
1. All new threads MUST be titled with a part number only. (i.e. 901.351.801.17)
2. Thread description should be an english description of the part. (i.e. Brake Dust Shields)
3. Replies to the thread are only restricted by pertinence. Some examples are original finish of the part (painted, cad plated, etc), common failures (cracking at the mount points), repair information or tips, pictures (stock or custom), upgrades, etc.
If you have any questions regarding the rules of this forum, please PM McMark.
DennisV |
Sep 16 2022, 03:26 PM
Member Group: Members Posts: 482 Joined: 8-August 20 From: Santa Rosa, CA Member No.: 24,575 Region Association: Northern California |
Also referred to by a variety of other names (e.g. alternator hub, fan extension, cooling deflector, air guide).
No visible part number. They can be found in 3, 5, and 6 mounting hole varieties. Metal or plastic fins. With and without cut-outs for voltage regulator. Research suggests 914-6 would have 6 mounting holes, and no notch for the regulator as that was mounted elsewhere. Porsche parts catalogs suggest it was shared with 1970-73 911 and 1978-83 911 Turbo. |
Lo-Fi Version | Time is now: 2nd June 2024 - 12:32 PM |
