Clutch Advice, Reuse or Replace? |
mzapisek |
Oct 9 2022, 08:43 AM
Member Group: Members Posts: 91 Joined: 10-June 04 From: Syracuse, NY Member No.: 2,188 Region Association: North East States |
I have very low mile original 1.7 (30K). I recently installed a 4 post lift and have begun doing all the 50 year service updates (SS fuel lines, shift bushings, engine refresh etc.). I am certainly a novice mechanic at best. The information on this board most definitely helps close the knowledge gap and encourages me to self perform tasks I would otherwise be unsure of. While inspecting the flywheel, clutch and pressure plate they appear to be in very good condition (no grooves or obvious signs of wear) just some slight discoloration.
Should I reuse or replace? I did purchase a new rear main seal but I do not see any signs of a leak. From other info I have read on this board the newer seals are/maybe somewhat substandard. While I welcome the opportunity to fix everything I can while the engine is out and on the stand don’t want to perform unnecessary work or look for problems that don’t exist. Would appreciate some advice. Thanks. |
FL000 |
Oct 9 2022, 09:27 AM
Member Group: Members Posts: 397 Joined: 31-January 12 From: Lancaster, CA Member No.: 14,076 Region Association: Southern California |
It’s a lot of work to get to where you are at. Cheap insurance to replace the pressure plate, disk, and throw out bearing while you are there. My thoughts.
Lockwodo |
Oct 9 2022, 09:51 AM
Member Group: Members Posts: 201 Joined: 23-December 21 From: Santa Cruz, Californnia Member No.: 26,193 Region Association: Northern California |
I have very low mile original 1.7 (30K). I recently installed a 4 post lift and have begun doing all the 50 year service updates (SS fuel lines, shift bushings, engine refresh etc.). I am certainly a novice mechanic at best. The information on this board most definitely helps close the knowledge gap and encourages me to self perform tasks I would otherwise be unsure of. While inspecting the flywheel, clutch and pressure plate they appear to be in very good condition (no grooves or obvious signs of wear) just some slight discoloration. Should I reuse or replace? I did purchase a new rear main seal but I do not see any signs of a leak. From other info I have read on this board the newer seals are/maybe somewhat substandard. While I welcome the opportunity to fix everything I can while the engine is out and on the stand don’t want to perform unnecessary work or look for problems that don’t exist. Would appreciate some advice. Thanks. Tech Tips 700 (Dr. 914) as a nice writeup on clutch renewal and what should be done. |
930cabman |
Oct 9 2022, 09:59 AM
Advanced Member Group: Members Posts: 3,128 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
Was it working properly prior to the teardown? If so, I would leave well enough alone
Ansbacher |
Oct 9 2022, 10:26 AM
Senior Member Group: Members Posts: 689 Joined: 4-July 14 From: Tampa Bay, Florida Member No.: 17,589 |
You will kick yourself later on if you don't replace everything questionable while you have things apart.
Ansbacher |
theer |
Oct 9 2022, 03:25 PM
Senior Member Group: Members Posts: 677 Joined: 31-July 15 From: Dover, MA Member No.: 19,014 Region Association: North East States |
Clutch job on a 914 is easier than on pretty much any other car… But it’s still a pretty big job.
I’m with the others… If it was my car, I would change out clutch, pressure plate and throw out bearing. Maybe add the pilot bearing, too. |
lesorubcheek |
Oct 9 2022, 04:30 PM
Member Group: Members Posts: 193 Joined: 21-April 21 From: Florida Member No.: 25,463 Region Association: South East States |
For the clutch disc, the Clymer manual recommends replacement if the thickness of the lining is less than 9mm (0.36"). Haynes recommends measuring the rivet depth, and if less than 0.6mm (0.025") then it's time to replace. Otherwise, if no obvious cracks or the lining being oil soaked, then it's OK to reuse. I'd imagine the factory manual has it's recommendations also.
For the pressure plate, look for signs of overheating, cracks, gouges. Haynes recommends using a straight edge on the face to look for visible warping. If the fingers (held on by rivets) are tight and not badly worn where the release bearing contacts, and everything else checks out OK, it should be fine to reuse. Almost everyone agrees to change the pilot bearing since it is fairly inexpensive and if there's any doubt about the release bearing, change it also. Look at those plastic insulating blocks on the release bearing too and replace if they look like there's any wear or cracks. Oh, and make sure to look at the flywheel face for gouges and uneven wear. I usually follow the "if it ain't broke, don't fix it" philosophy. It's really up to you. Quick search looks like around 200-300 bucks for a new pressure plate and disc. If that seems like peanuts too you, then sure why not replace it while you're in there. If you feel like that's money that could better be spent elsewhere, the parts look good and you don't mind jumping back in maybe in 10, 20, 30 thousand miles (depends on how hard you drive it) then personally I see no reason the parts can't be reused. |
914Sixer |
Oct 10 2022, 06:17 AM
914 Guru Group: Members Posts: 8,897 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Since it is out do it right. Replace everything. Make sure you get the little stuff. Replace pivot ball if needed. Plastic ball cup on fork along with the spacers on release bearing, Clean up flywheel. Replace rear seal and flywheel O ring. Basic kit $290 Rockauto KF19101
Attached image(s) |
mzapisek |
Oct 10 2022, 07:04 AM
Appreciate all the advice. I think I will keep the flywheel and change everything else out as suggested. This place is such a good resource.
Montreal914 |
Oct 10 2022, 08:07 AM
Senior Member Group: Members Posts: 1,571 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California |
mgphoto |
Oct 10 2022, 05:09 PM
"If there is a mistake it will find me" Group: Members Posts: 1,339 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
Do the fingernail test, on the metal surfaces, flywheel and pressure plate, run your fingernail the radius of the surfaces, outer edge to the center. Does your fingernail catch on any ridges? Very smooth ridges which are not deep might be ok but sharp and deep, resurface the flywheel and replace the pressure plate. I have replace a clutch in my car during super bowl halftime, using a floor jack. Today I have a lift but I don’t have to rush anymore.
windforfun |
Oct 10 2022, 06:12 PM
Senior Member Group: Members Posts: 1,822 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None |
Why should you need a new clutch with only 30K miles on the car?
(IMG:style_emoticons/default/WTF.gif) (IMG:style_emoticons/default/WTF.gif) (IMG:style_emoticons/default/WTF.gif) |
bbrock |
Oct 10 2022, 07:41 PM
Why should you need a new clutch with on 30K miles on the car? (IMG:style_emoticons/default/WTF.gif) (IMG:style_emoticons/default/WTF.gif) (IMG:style_emoticons/default/WTF.gif) (IMG:style_emoticons/default/agree.gif) |
Mikey914 |
Oct 10 2022, 08:08 PM
The rubber man Group: Members Posts: 12,677 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Welcome to "While I was there" this is the all too familiar rabbit hole we go down.
If you can get good quality parts at $270, probably not worth the effort to do again if it becomes an issue. You can always do the CSOB way and replace the disk and sand the flywheel and pressure plate (IMG:style_emoticons/default/shades.gif). The cost is $20ish. If it truly is a 30k car it should suffice. BTW I have the cup sockets if you need them. -Mark |
TMM914 |
Oct 10 2022, 08:12 PM
Newbie Group: Members Posts: 33 Joined: 1-January 20 From: St Jacobs Ontario Canada Member No.: 23,786 Region Association: Canada |
I am in for replacing the complete clutch setup.We have to remember that although it is low miles it is still 50 ish years old. If it’s out….replace it.
bbrock |
Oct 10 2022, 10:16 PM
Unless it rusts, I don't see how a clutch would go bad just because of age. I would give all the parts a thorough inspection as others have described. If anything is suspect or anywhere near the wear limit, replace the whole kit. If not, replace the RMS and flywheel O-ring and reinstall the rest. There's a good chance that clutch has another 30K of life left on it under normal street use. It's all relative, but $300 is not cheap on my salary and replacing a clutch is just not that much work - especially with access to a lift. I've never had a clutch go out without giving me plenty of warning it was on its way first.
mzapisek |
Oct 11 2022, 07:12 AM
My mindset is whatever I do will be the last time I would touch it so might as well eliminate any work down the line. Car is not driven a lot so should be the last time during my ownership.
Superhawk996 |
Oct 11 2022, 07:42 AM
914 Guru Group: Members Posts: 5,875 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Front yard mechanic |
Oct 11 2022, 07:49 AM
Senior Member Group: Members Posts: 1,169 Joined: 23-July 15 From: New Mexico Member No.: 18,984 Region Association: None |
I say reuse it. We all need more exercise (IMG:style_emoticons/default/cheer.gif)
Superhawk996 |
Oct 11 2022, 08:21 AM
For the clutch disc, the Clymer manual recommends replacement if the thickness of the lining is less than 9mm (0.36"). Haynes recommends measuring the rivet depth, and if less than 0.6mm (0.025") then it's time to replace. Otherwise, if no obvious cracks or the lining being oil soaked, then it's OK to reuse. I'd imagine the factory manual has it's recommendations also. Strangely I can’t seem to find a spec in disc thickness in the 914 factory manual (IMG:style_emoticons/default/confused24.gif) |
Lo-Fi Version | Time is now: 1st June 2024 - 12:38 AM |
