| L-Jet914 |
Apr 12 2023, 05:56 PM
Member ![]() ![]() Group: Members Posts: 444 Joined: 24-October 12 From: Davis, CA Member No.: 15,080 Region Association: Northern California |
I know a member(s)were asking about tire to lift clearance on the 7000lb version of the QuickJack system. I have the 7000SLX model. Tire clearance is just fine if setup up in the right position.
Attached thumbnail(s) |
| bkrantz |
Apr 12 2023, 08:06 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,827 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains
My problem is with the extended length 7000TLX. Even with the lift pushed against the rear tire, it makes contact with the front tire as it rises.
| L-Jet914 |
Apr 12 2023, 10:36 PM
I believe mine is the non-extended length. The extended length ones are recommended for trucks with long wheelbases from what I remember reading on QuickJack's website. With the 7000TL(the updated version of the 7000SLX) I believe you would be okay.
Lo-Fi Version | Time is now: 28th November 2026 - 03:06 AM |
