Fuel injector hose “clamp” |
r_towle |
Apr 27 2023, 07:09 PM
Custom Member Group: Members Posts: 24,591 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Is there a less dramatic method to remove the clamp that hold the rubber hose to the injector? It’s not a screw clamp, it’s some sort of crimped fitting.
I’m thinking Dremel with a cutoff wheel? This is to replace the hoses. |
Geezer914 |
Apr 27 2023, 07:22 PM
Geezer914 Group: Members Posts: 1,447 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States |
Dremel with a cut off wheel or a sharp pair of wire cutters!
rjames |
Apr 27 2023, 11:53 PM
I'm made of metal Group: Members Posts: 3,956 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
It’s been awhile, but pretty sure I used wire cutters.
dr914@autoatlanta.com |
Apr 28 2023, 08:44 AM
914 Guru Group: Members Posts: 7,898 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
wire cutters to snip it off or a hacksaw blade
Is there a less dramatic method to remove the clamp that hold the rubber hose to the injector? It’s not a screw clamp, it’s some sort of crimped fitting. I’m thinking Dremel with a cutoff wheel? This is to replace the hoses. |
Lo-Fi Version | Time is now: 11th June 2024 - 03:58 AM |
