123 Ignition distributor - Curve B |
dams69 |
May 7 2023, 09:40 AM
Newbie Group: Members Posts: 7 Joined: 18-September 20 From: France Member No.: 24,701 Region Association: None |
Hello,
I installed 2 weber 44 carburetors with a Webcam 86A camshaft and I have a 123ignition distributor. From my readings, I use curve B. I set the advance to 8° at 900rpm. does that seem correct to you? (IMG:style_emoticons/default/smile.gif) (IMG:http://www.914world.com/bbs2/uploads_offsite/zupimages.net-24701-1683474041.1.jpg) |
mgphoto |
May 8 2023, 09:47 AM
"If there is a mistake it will find me" Group: Members Posts: 1,339 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
Hello, I installed 2 weber 44 carburetors with a Webcam 86A camshaft and I have a 123ignition distributor. From my readings, I use curve B. I set the advance to 8° at 900rpm. does that seem correct to you? (IMG:style_emoticons/default/smile.gif) (IMG:http://www.914world.com/bbs2/uploads_offsite/zupimages.net-24701-1683474041.1.jpg) Advance is set at 27* at 3500 rpm (8* is for L-Jet setup) |
Lo-Fi Version | Time is now: 7th June 2024 - 06:40 AM |
