Adjusting Idle PMO Carbs - Six Cylinder |
mmascari |
Jun 16 2023, 02:23 PM
Member Group: Members Posts: 321 Joined: 1-September 14 From: Concord, CA Member No.: 17,850 Region Association: None |
Do I turn the idle adjuster clockwise or counter-clockwise to Increase the idle?
porschetub |
Jun 16 2023, 04:13 PM
Advanced Member Group: Members Posts: 4,703 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
brant |
Jun 16 2023, 04:14 PM
914 Wizard Group: Members Posts: 11,632 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
Wrong thread
Delete |
Steve |
Jun 16 2023, 05:45 PM
914 Guru Group: Members Posts: 5,606 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
Do I turn the idle adjuster clockwise or counter-clockwise to Increase the idle? Clockwise, but remove the cross bar from one side when making the adjustment. I also used the ball thingy on the throats to make sure they were the same on both sides. Then put the cross bar back on and adjust accordingly if it throws the carbs off. https://www.amazon.com/Latest-Rage-53857308...24882&psc=1 |
nditiz1 |
Jun 16 2023, 07:00 PM
Senior Member Group: Members Posts: 1,190 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region |
As Steve said.
Don't buy that one from Moore Parts/latest Rage it is garbage. Spring 20 more for the German brand one. |
porschetub |
Jun 20 2023, 04:44 PM
Do I turn the idle adjuster clockwise or counter-clockwise to Increase the idle? Clockwise, but remove the cross bar from one side when making the adjustment. I also used the ball thingy on the throats to make sure they were the same on both sides. Then put the cross bar back on and adjust accordingly if it throws the carbs off. https://www.amazon.com/Latest-Rage-53857308...24882&psc=1 My experience was I found I hadn't exactly set up the drop links after replacing the worn ball cups ,found when hooking up the crossbar again it was clearly obvious they weren't even. Reset them and much improved,rebuilt the all the crossbar throttle linkages as due wear on those ball cups I had lots of slack in the system @ those points. IMO if all this is sorted and your carbs are fresh and you have even vacuum on all throats set up is pretty straight forward. Cheers. |
Luke M |
Jun 20 2023, 07:18 PM
Senior Member Group: Members Posts: 1,373 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States |
porschetub |
Jun 20 2023, 11:36 PM
Ok but the title was "PMO carbs" from the OP ???. |
VaccaRabite |
Jun 21 2023, 08:34 AM
En Garde! Group: Admin Posts: 13,456 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Ok but the title was "PMO carbs" from the OP ???. linkage adjustment is the same, either way. Zach |
porschetub |
Jun 21 2023, 02:45 PM
Ok but the title was "PMO carbs" from the OP ???. linkage adjustment is the same, either way. Zach Exactly. |
Lo-Fi Version | Time is now: 31st May 2024 - 06:12 PM |
