defrost light on the floor, power source |
EJP914 |
Jul 30 2023, 06:28 PM
Member Group: Members Posts: 260 Joined: 14-June 03 From: Monroeville, PA Member No.: 821 |
Can someone tell me where the single black/blue wire that provides power for the defrost light on the floor behind the shifter comes from? What or where is the other end connected to?
When I screw the light holder to the floor and connect the wire I blow out fuse 7 on the fuse panel. It looks like it is coming from the back of the car, but maybe not??? Would appreciate the help. Thanks EJP914 |
davep |
Jul 30 2023, 06:59 PM
914 Historian Group: Benefactors Posts: 5,152 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
Basically it is fed from the headlight switch along with all of the instrument gauge bulbs. The black/blue wire is the +12v side going to the bulb, and it grounds through the screw fastening the base assembly to the tunnel; or if in a center console there is a brown wire that connects to it.
Lo-Fi Version | Time is now: 8th June 2024 - 09:58 AM |
