Fuel shut off valve recommendation |
narino |
Sep 1 2023, 05:45 PM
Member Group: Members Posts: 231 Joined: 14-August 07 From: Los Angeles, CA Member No.: 8,001 Region Association: None |
Hi all, looking to put a shut off valve at the front for filter swap ease, and another in the engine bay to use to run the carbs dry. Last one I bought leaked like crazy and went directly into the trash. Thought to ask what others are using.
TIA Hope everyone has a great holiday weekend! |
windforfun |
Sep 1 2023, 05:49 PM
Senior Member Group: Members Posts: 1,809 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None |
Use C-clamps. If your soft lines are still supple, you won't do any damage. My 2 cents.
ClayPerrine |
Sep 1 2023, 06:37 PM
Life's been good to me so far..... Group: Admin Posts: 15,490 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Put in an electric switch to turn the fuel pump off. Then run the engine until it dies from lack of gas.
FlacaProductions |
Sep 1 2023, 07:00 PM
Senior Member Group: Members Posts: 1,598 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
just pull the fuel pump fuse? then run it til it dies...
Lo-Fi Version | Time is now: 29th May 2024 - 05:45 AM |
