DennisV |
Senior Member ![]() ![]() ![]() Group: Members Posts: 607 Joined: 8-August 20 From: Santa Rosa, CA Member No.: 24,575 Region Association: Northern California ![]() ![]() |
TLDR;
I attempted to install rear trailing arm pivot shafts into new bushings over the weekend and it was a disaster. First go split the bushing. Second go with bushing from alternate vendor went in by hand. I assume if it went in that easy, something is not right. DETAIL I started with new shafts from Restoration Design, as they seemed closest to original design (i.e., hollow). I also used their Prekom brand bushings as I was told it was the original durometer and being supplied to Porsche, Rebel Racing and Elephant Racing. The trailing arm bushing split the top lip from the base on the first attempt to install a pivot shaft. Per conventional wisdom, I thoroughly lubricated them with dish soap, used a shop press, and had a helper. I didn’t want to mix bushings with different specs, so I pull out all the Prekom. They seemed pretty brittle and broke apart in most cases. Note: The dimensions (mm) of the bushing are quite different. Left to right in photos. WDG ID: 28, Height 54 Prekom ID: 26, Height 47 Original ID: 28.5, Height 55 I wish I had measured the OD of the new pivot shaft, but didn't think to do it before installing them. ![]() ![]() I tried again to install, this time with the same pivot shaft but using WDG bushing which I had on hand and are very close to the same dimensions of the originals. In this case I was able to install the pivot shaft into the bushings by hand. I assume it should not be that easy. (IMG:style_emoticons/default/WTF.gif) They did appear to set up a bit after leaving them overnight, but I am able to rotate the link bearing by hand with some moderate effort. Nut torqued, but not installed on car. So now I am left to decide if I leave it as is, or pull the pivot shaft and bushing and start over with another combination. (IMG:style_emoticons/default/confused24.gif) |
Superhawk996 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,033 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch ![]() ![]() |
Yes - they are a pain to install when you have the proper preload or squish between the ID and OD.
I successfully used restoration design bushings but did tear one due to not enough lube and trying to press it too fast. I ordered a 2nd set and had no issue once the lesson was learned about how fast to press them in. And you can never have too much lube. I prefer glycerin over dish soap. You are absolutely correct they should not install by hand. |
Mikey914 |
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,767 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None ![]() ![]() |
We make bushings and shafts that are the same dimensions as the OEM. I do know with ours it it a tight tolerance, and is not a hand fit. It can however be tapped into place with lubrication.
DennisV |
We make bushings and shafts that are the same dimensions as the OEM. I do know with ours it it a tight tolerance, and is not a hand fit. It can however be tapped into place with lubrication. Hi Mike. The second set of bushings that I used, where I was able to install the shaft by hand, were from 914Rubber. Marked WDG. Perhaps the pivot shafts from Restoration Design are not stock OD. Though if they were smaller, I wouldn't have thought my first install try would have ended like it did. |
76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,700 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
That shaft shouldn't rotate easily. It should be tighter than socks on a Rooster. Your suspension depends upon the drop arm not rotating unless a lot of torque is applied. At least you didn't install those urethane POS bushings. (IMG:style_emoticons/default/beerchug.gif)
Krieger |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,803 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None ![]() ![]() |
Hi Dennis. I have a good pair of oem pivot shafts you could borrow if you want to try them on for size.
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,876 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
We make bushings and shafts that are the same dimensions as the OEM. I do know with ours it it a tight tolerance, and is not a hand fit. It can however be tapped into place with lubrication. Hi Mike. The second set of bushings that I used, where I was able to install the shaft by hand, were from 914Rubber. Marked WDG. Perhaps the pivot shafts from Restoration Design are not stock OD. Though if they were smaller, I wouldn't have thought my first install try would have ended like it did. I know early 914rubber bushings were a loose fit. I purchased 2 sets from the initial group buy. They might have changed things in later production runs. |
914Toy |
Senior Member ![]() ![]() ![]() Group: Members Posts: 746 Joined: 12-November 17 From: Laguna beach Member No.: 21,596 Region Association: Southern California ![]() ![]() |
That shaft shouldn't rotate easily. It should be tighter than socks on a Rooster. Your suspension depends upon the drop arm not rotating unless a lot of torque is applied. At least you didn't install those urethane POS bushings. (IMG:style_emoticons/default/beerchug.gif) "Socks on a rooster" (IMG:style_emoticons/default/av-943.gif) |
Montreal914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,818 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California ![]() ![]() |
How does one can establish what the dimensions and tolerance of the original could have been?
Were these ever available separately, uninstalled, so they could be measured and reversed engineered as such? (IMG:style_emoticons/default/confused24.gif) |
DennisV |
Hi Dennis. I have a good pair of oem pivot shafts you could borrow if you want to try them on for size. Thanks for the kind offer Andy. The car is in MO, so it would be tough to fit at the moment. (IMG:style_emoticons/default/biggrin.gif) I did measure the originals I removed. They were about 28.2mm OD. Wish I had measured the RD ones before install. I guess I'll get another chance when I take them back out. (IMG:style_emoticons/default/mad.gif) |
mepstein |
How does one can establish what the dimensions and tolerance of the original could have been? Were these ever available separately, uninstalled, so they could be measured and reversed engineered as such? (IMG:style_emoticons/default/confused24.gif) I haven’t tried all the options but Elephant racing is the closest to stock that I’ve used. |
76-914 |
How does one can establish what the dimensions and tolerance of the original could have been? Were these ever available separately, uninstalled, so they could be measured and reversed engineered as such? (IMG:style_emoticons/default/confused24.gif) I haven’t tried all the options but Elephant racing is the closest to stock that I’ve used. (IMG:style_emoticons/default/agree.gif) You pay through the nose but well worth it. (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 10th May 2025 - 11:39 AM |
