H4 headlamp conversion - rubber dust boots? |
DC_neun_vierzehn |
Jan 25 2024, 02:00 PM
Member Group: Members Posts: 387 Joined: 16-November 20 From: Delaware Shore Member No.: 24,893 Region Association: MidAtlantic Region |
fiacra |
Jan 25 2024, 02:13 PM
Person.Woman.Man.Camera.TV Group: Members Posts: 338 Joined: 1-March 19 From: East Bay Region - California Member No.: 22,920 Region Association: Northern California |
For those that converted to H4 headlamps, did you install the rubber dust boots on the back? And if so, did you remove the plastic plug on the wiring to fit the dust boot on or did you modify the rubber dust boot to accommodate the plug? TIA Am I misunderstanding something here? The rubber boot fits on over the three spade connectors coming off the bulb and then you put the connector on..... |
GregAmy |
Jan 25 2024, 02:14 PM
Advanced Member Group: Members Posts: 2,311 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
Yup. Push the boot on the back after inserting the bulb and the three terminals will protrude through those holes. Plug in the headlight connector and done.
Cairo94507 |
Jan 25 2024, 02:29 PM
Michael Group: Members Posts: 9,808 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
Absolutely. Push it on and then plug it in. (IMG:style_emoticons/default/beerchug.gif)
DC_neun_vierzehn |
Jan 25 2024, 05:07 PM
Ok. I'll take another look. Sounds like I am overcomplicating this.
rhodyguy |
Jan 25 2024, 05:20 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,084 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Helps keep dirt and moisture out and the inside of the lens clear.
Lo-Fi Version | Time is now: 1st June 2024 - 12:36 AM |
