| pete-stevers |
Feb 2 2024, 05:22 PM
Shinee Side Up ![]() ![]() ![]() ![]() Group: Members Posts: 2,681 Joined: 10-October 04 From: Abbotsford,BC, Canada Member No.: 2,914 Region Association: Pacific Northwest
I dont really have room in the garage for a two post lift.. so I figure a scissor lift might be better... let me know what you think. My ceiling is 11 feet and don't want to spend more than 2000 ish... or am i out to lunch...
| FlacaProductions |
Feb 2 2024, 05:59 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,294 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California
EZ-CarLift and a high speed drill.
https://www.ezcarlift.com no hyraulic fluid or auxiliary boxes, etc. |
| Cairo94507 |
Feb 2 2024, 06:06 PM
Michael ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,798 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California
In my last home I did a mid-rise scissor lift, BendPak, and I loved it. Sunk into garage floor so when it was down, totally flush with the floor- no trip hazard. We ran the hydraulic lines in the floor too. Mounted the mechanicals under a counter in a cabinet and the only thing you saw was a control panel with the controls on the side of a cabinet. Very low-profile, clean install.
If you send me your email address I can send you photos. Cheers, Michael (IMG:style_emoticons/default/beerchug.gif) |
| mepstein |
Feb 2 2024, 06:12 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,983 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
Any decent lift will be a game changer.
| tygaboy |
Feb 2 2024, 06:23 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,862 Joined: 6-October 15 From: Petaluma, CA Member No.: 19,241 Region Association: Northern California
I have QuickJacks and love them. I don't like sissor lifts because they block so much of the underside, they are HEAVY and take up a lot of room.
Price aside, have you looked at MaxJacks? Portable 2-post that work with low ceilings. https://www.maxjax.com/ |
| bandjoey |
Feb 2 2024, 06:49 PM
bandjoey ![]() ![]() ![]() ![]() Group: Members Posts: 4,935 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
EZ-CarLift and a high speed drill. https://www.ezcarlift.com no hyraulic fluid or auxiliary boxes, etc. Can you do valve adjustments with this lift? Looks like the side bars block that area |
| JeffBowlsby |
Feb 2 2024, 07:07 PM
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,385 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None
How about a used 4-post lift? 11ft clear is sufficient and a 4-post gives you storage space and great access from below.
| pete-stevers |
Feb 2 2024, 07:39 PM
How is dropping engines with a scissor lift? or engine access?
| BillJ |
Feb 2 2024, 07:57 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,356 Joined: 4-March 13 From: charlotte, NC Member No.: 15,610 Region Association: None
Love my quickjack.
| Freezin 914 |
Feb 2 2024, 08:28 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 942 Joined: 27-July 14 From: Wisconsin Member No.: 17,687 Region Association: Upper MidWest
In the past have had a scissors lift (titan), and now have a quick Jack. They both have their place, including every other lift listed. Personally, quick jacks are great for a guy like me, weekend warrior, small maintenance projects, if I where doing more serious repairs, restoration, rebuilding,or had multiple cars, I would consider something more robust like a MaxJack, 4 post, or scissors again. Just my .02 as most have said, any lift is better than a floor Jack…
| Mitox |
Feb 2 2024, 09:05 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 576 Joined: 26-October 15 From: SW Virginia Member No.: 19,302 Region Association: South East States
| Freezin 914 |
Feb 2 2024, 09:08 PM
| Mitox |
Feb 2 2024, 09:20 PM
| dhuckabay |
Member ![]() ![]() Group: Members Posts: 238 Joined: 14-June 20 From: Idaho Member No.: 24,379 Region Association: Pacific Northwest
I got a two post Chinese lift off ebay. Think it was about 1500 delivered. Installed in a half day. Really well built. My son is a mechanic and uses it a lot. Never had any problems with it. Very good safety devices to keep it from coming down at the wrong time. Did build some wood pads to elevate the low slung cars.
| Krieger |
Feb 2 2024, 11:25 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,897 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None
EZ-CarLift and a high speed drill. https://www.ezcarlift.com no hyraulic fluid or auxiliary boxes, etc. Can you do valve adjustments with this lift? Looks like the side bars block that area Yes you can. I have 2 different length crossbars (not the aluminum rails you see). Depending on what I am doing I run the aluminum rails on the sides of the car, or sometimes turned 90°. The EZ lift is 120#s. I stand mine against the wall when I am not using it. |
| Rufus |
Feb 3 2024, 12:48 AM
Member ![]() ![]() Group: Members Posts: 314 Joined: 8-April 06 Member No.: 5,840 Region Association: None
How about a used 4-post lift? 11ft clear is sufficient and a 4-post gives you storage space and great access from below. I bought a used Rotary 4 post. Installation under a 10.5’ ceiling was a pretty straight forward one man job. IIRC required renting a hammer drill for putting holes in garage floor. Other tools like a good (laser’s best) level, plumb bob (I used to check level accuracy), are recommended. Still in my garage but not set up now, but miss it almost every day. Very useful for storing and / or working on cars. Having a 914’s a plus due to its low height. Something to keep in mind when comparing the height stack up of cars and lift (for storage use) to ceiling height, it’s important to subtract the total floor slope from the ceiling height. Builders typically build in a slope for water drainage. If I’d considered this beforehand, I would have insisted on a zero slope floor. |
| mlindner |
Feb 3 2024, 05:15 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,807 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest
| mlindner |
Feb 3 2024, 05:23 AM
| BK911 |
Feb 3 2024, 06:51 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 672 Joined: 19-February 04 From: Rocky Top, TN Member No.: 1,674 Region Association: None |
Another vote for harbor freight.
Had mine for 20 years. Dozens of 911 912 356 914 had brake suspension or engine work done over the years. One of the best tools I ever bought. |
| mlindner |
Feb 3 2024, 08:23 AM
Topliftcar, has the Bendpak lift for $1,500 with free shipping.
Lo-Fi Version | Time is now: 7th November 2026 - 03:24 PM |
