| DC_neun_vierzehn |
Mar 14 2024, 09:44 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 595 Joined: 16-November 20 From: Coastal Delaware Member No.: 24,893 Region Association: MidAtlantic Region
From day one when I bought my 914 a couple of years ago, when I turned the wipers on, they would park wherever they were on the windshield when I turned the wiper switch to the off position (they would NOT go back to the normal park position at 9:00).
Thus, I had to keep turning the switch on and off until I got them where they should park at the bottom of the windshield at 9:00. I thought replacing the wiper switch would do the trick. I installed a NOS SWF wiper switch and now the wipers go to a park position after turning the switch off, but that park position is at about 1:00. I tried removing the wiper arms and adjusting them to see if I could solve the problem, but no dice. With the wiper arms removed, and the wiper switch in the off position, I should be able to install the wiper arms at the 9:00 position and when I turn the switch on they should operate properly. But when I do that and turn the switch on, they go down onto the hood. In order to avoid the wipers from going onto the hood I have install them at the 1:00 position and when I turn the switch on they clean the whole windshield but park at 1:00 when the switch is in the off position. What the heck is going on here? It's almost like the PO installed the wiper motor backwards. Is that even possible? |
| mrholland2 |
Mar 14 2024, 10:34 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 761 Joined: 7-September 11 From: Santa Maria,CA Member No.: 13,531 Region Association: Central California |
From day one when I bought my 914 a couple of years ago, when I turned the wipers on, they would park wherever they were on the windshield when I turned the wiper switch to the off position (they would NOT go back to the normal park position at 9:00). Thus, I had to keep turning the switch on and off until I got them where they should park at the bottom of the windshield at 9:00. I thought replacing the wiper switch would do the trick. I installed a NOS SWF wiper switch and now the wipers go to a park position after turning the switch off, but that park position is at about 1:00. I tried removing the wiper arms and adjusting them to see if I could solve the problem, but no dice. With the wiper arms removed, and the wiper switch in the off position, I should be able to install the wiper arms at the 9:00 position and when I turn the switch on they should operate properly. But when I do that and turn the switch on, they go down onto the hood. In order to avoid the wipers from going onto the hood I have install them at the 1:00 position and when I turn the switch on they clean the whole windshield but park at 1:00 when the switch is in the off position. What the heck is going on here? It's almost like the PO installed the wiper motor backwards. Is that even possible? I'm not sure if this applies, but there is something built into the motor assemblies of most wipers that return to park position when the switch is off? A relay? Maybe it isn't built in on the 914, not sure. I know I had one car that the switch only sort of turned off the power and when the wipers "parked" they depressed a button that turned off all the power. I'm rambling, but it makes sense in my head |
| Root_Werks |
Mar 14 2024, 11:07 AM
Village Idiot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,845 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest
I thought there was something that controlled the park position. I know if I mist my wipers, they park up about an inch too high. If they are running and turned off, they park correctly. Sort of annoying.
| Superhawk996 |
Mar 14 2024, 11:26 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,521 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
Controlled by a rotating, cam shaped switch in the headlight motor drive assembly.
More: http://www.914world.com/bbs2/index.php?sho...=304921&hl= |
| ClayPerrine |
Mar 14 2024, 12:36 PM
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,526 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille
The arm that drives the wipers is installed in the wrong position on the wiper motor.
1. Take the arm off the wiper motor shaft. 2. Turn the wipers on and then off so the motor goes to the park position. 3. Position the arm so that the wipers are in the correct park position on the windshield. 4. (IMG:style_emoticons/default/beer3.gif) |
| DC_neun_vierzehn |
Mar 14 2024, 01:47 PM
The arm that drives the wipers is installed in the wrong position on the wiper motor. 1. Take the arm off the wiper motor shaft. 2. Turn the wipers on and then off so the motor goes to the park position. 3. Position the arm so that the wipers are in the correct park position on the windshield. 4. (IMG:style_emoticons/default/beer3.gif) I'm almost afraid to ask ... what do I need to remove to get to these places? Isn't the fresh air box and gas tank in the way? Or can I work around that stuff to do this? |
| 914_teener |
Mar 14 2024, 02:45 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,268 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
The arm that drives the wipers is installed in the wrong position on the wiper motor. 1. Take the arm off the wiper motor shaft. 2. Turn the wipers on and then off so the motor goes to the park position. 3. Position the arm so that the wipers are in the correct park position on the windshield. 4. (IMG:style_emoticons/default/beer3.gif) Think Clay is right...Occum's Razor thing....but maybe also the cam contacts are worn or gunky. Try indexing them first as Clay says. |
| ClayPerrine |
Mar 14 2024, 02:48 PM
The arm that drives the wipers is installed in the wrong position on the wiper motor. 1. Take the arm off the wiper motor shaft. 2. Turn the wipers on and then off so the motor goes to the park position. 3. Position the arm so that the wipers are in the correct park position on the windshield. 4. (IMG:style_emoticons/default/beer3.gif) I'm almost afraid to ask ... what do I need to remove to get to these places? Isn't the fresh air box and gas tank in the way? Or can I work around that stuff to do this? If you are agile, you can get to the end of the shaft end of the wiper motor without removing the fresh air box. Otherwise you have to pull the gas tank and the fresh air box to fix it. Good luck. |
| 914_teener |
Mar 14 2024, 02:51 PM
The arm that drives the wipers is installed in the wrong position on the wiper motor. 1. Take the arm off the wiper motor shaft. 2. Turn the wipers on and then off so the motor goes to the park position. 3. Position the arm so that the wipers are in the correct park position on the windshield. 4. (IMG:style_emoticons/default/beer3.gif) I'm almost afraid to ask ... what do I need to remove to get to these places? Isn't the fresh air box and gas tank in the way? Or can I work around that stuff to do this? Yep....one of the most cursed jobs in a 914. If you are agile, you can get to the end of the shaft end of the wiper motor without removing the fresh air box. Otherwise you have to pull the gas tank and the fresh air box to fix it. Good luck. |
| rgalla9146 |
Mar 14 2024, 07:40 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,856 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None
(IMG:style_emoticons/default/agree.gif) with Clay
If you can get a long 10mm open end wrench in there to loosen the nut you're half way there. Now you'll have to pry that first arm up off the splined shaft. As I recall the correctly positioned arm will now intefere with tightening the 10mm nut. I may have it wrong here. I have moved that arm at times in the past to park the wipers on the passenger side. Good Luck By the way, remove the wiper arms before doing any of this and disconnect the battery too. |
| bkrantz |
Mar 14 2024, 07:55 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,530 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains
The arm that drives the wipers is installed in the wrong position on the wiper motor. 1. Take the arm off the wiper motor shaft. 2. Turn the wipers on and then off so the motor goes to the park position. 3. Position the arm so that the wipers are in the correct park position on the windshield. 4. (IMG:style_emoticons/default/beer3.gif) Not sure about this. If the wiper arms currently swing in the correct arc, then moving the arms on the shafts will cause them to make contact with the windshield frame, and maybe beyond onto the paint. Where the arms park when the switch goes to "off" is another issue. |
| Dave_Darling |
Mar 14 2024, 08:19 PM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,289 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
He's not talking about the wiper arms. He's talking about the bellcrank that attaches the whole wiper mechanism to the motor. It's not moving where the wipers are in relation to the stopping point, it's moving the stopping point itself.
--DD |
| fixer34 |
Mar 14 2024, 08:26 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,355 Joined: 16-September 14 From: Chicago area Member No.: 17,908 Region Association: Upper MidWest
As noted, that is also what you do if you want to park the wipers on the passenger side.
| DC_neun_vierzehn |
Jun 19 2024, 10:32 AM
Ok. Finally getting around to addressing my wipers and the park position while I’m trying to install a new gas tank and rebuild my fresh air box.
While inspecting the old wiper assembly, I found a lot of wear and play that I didn’t like. So I’m swapping in a nice backup wiper motor assembly I had on the shelf. I have a new rubber isolator from 914 Rubber to replace the one that has basically disintegrated. The one end of the old isolator came off easy but the other end that attaches to the car is stumping me. How do I get that thing out? |
| DC_neun_vierzehn |
Jun 19 2024, 10:47 AM
I’m guessing I have to get it from inside the car, under the dash. I have a center console that feels like it will be impossible to get to that nut and bolt. Am I wrong or will I likely have to remove some of the center console to get to it? I canr see the nut but I think I can see a few threads on a shift about where the isolator would enter the cabin.
| Olympic 914 |
Jun 19 2024, 11:05 AM
![]() ![]() ![]() Group: Members Posts: 1,762 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States
| DC_neun_vierzehn |
Jun 19 2024, 12:36 PM
Unfortunately there’s nothing in that thread that mentions the rubber isolator foot. |
| DC_neun_vierzehn |
Jun 19 2024, 02:57 PM
This video helped me figure it out (from around the 10 min mark to the 14 min mark it's covered. You have to remove the speedo to access that isolator foot from the cabin.
https://www.youtube.com/watch?v=A6m74VEitzE |
| DC_neun_vierzehn |
Jun 19 2024, 04:10 PM
Here is the access point (speedo removed and looking through the speedo hole in the gauge cluster):
Attached thumbnail(s) |
| DC_neun_vierzehn |
Jun 20 2024, 11:29 AM
The arm that drives the wipers is installed in the wrong position on the wiper motor. 1. Take the arm off the wiper motor shaft. 2. Turn the wipers on and then off so the motor goes to the park position. 3. Position the arm so that the wipers are in the correct park position on the windshield. 4. (IMG:style_emoticons/default/beer3.gif) Thank you @ClayPerrine . This process worked like a charm. Took a few attempts at getting the arm positioned correctly on the motor shaft. Had to reinstall, remove, and adjust a few times. But I eventually got it perfect. A few hours later, the replacement motor and assembly is in the car and working beautifully. Now on to the Fresh Air Box rebuild and reinstall. |
Lo-Fi Version | Time is now: 15th November 2025 - 12:16 PM |
