| partwerks |
Nov 9 2024, 10:37 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,619 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
What is the procedure to remove the dash frame, once the dash is removed?
| Shivers |
Nov 9 2024, 02:03 PM
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,335 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
| partwerks |
Nov 16 2024, 08:31 AM
The studs are all under the cowl where the windshield wiper unit is. the other is under the dash. then two on each side as I remember. I've had this one in and out countless times, it always messes with me coming out. The studs in the holes don't give up easily Can it be removed with the top of the dash still in place, or does it have to be removed first? |
| Shivers |
Nov 16 2024, 08:50 AM
The studs are all under the cowl where the windshield wiper unit is. the other is under the dash. then two on each side as I remember. I've had this one in and out countless times, it always messes with me coming out. The studs in the holes don't give up easily Can it be removed with the top of the dash still in place, or does it have to be removed first? I do not see why not, it is only attached to the frame. |
| mepstein |
Nov 16 2024, 08:51 AM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,587 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
The studs are all under the cowl where the windshield wiper unit is. the other is under the dash. then two on each side as I remember. I've had this one in and out countless times, it always messes with me coming out. The studs in the holes don't give up easily Can it be removed with the top of the dash still in place, or does it have to be removed first? I do not see why not, it is only attached to the frame. It can. Some people pre-install the dash pad before installing the sub frame. |
| TonyA |
Nov 16 2024, 09:27 AM
Nachmal ![]() ![]() ![]() Group: Members Posts: 669 Joined: 17-November 16 From: Hilltown PA Member No.: 20,596 Region Association: North East States
See Ian karr's video on dash restoration.
| iankarr |
Nov 16 2024, 04:20 PM
The wrencher formerly known as Cuddy_K ![]() ![]() ![]() ![]() Group: Members Posts: 2,595 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region
Lo-Fi Version | Time is now: 2nd April 2026 - 08:47 AM |
