| s13u74cr4 |
Nov 30 2024, 04:09 PM
Member ![]() ![]() Group: Members Posts: 61 Joined: 2-September 23 From: PNW Member No.: 27,558 Region Association: Pacific Northwest |
Based on community knowledge gathered in a previous post it turns out the PO of my 73 2.0 had the supply and return lines reversed underneath. I now have ALL NEW hoses AND the correct fuel filter AND a reducer pipe from Tangerine, but want to make sure I am right before I start cutting the lines.
Going off this diagram: (IMG:https://bowlsby.net/914/Classic/zTN_FI_Hose_FuelPump_1970-74.jpg) If I use the measurements there I will have too much in some spots and too little in others. I am guessing these numbers are not based of having SS lines? Does it matter is I have more/less in runs between connections? And, I believe the SS lines above the shelf are correct. Supply in front and return in the rear. On the underside you can see where that positions them which is tight. |
| ndfrigi |
Nov 30 2024, 09:59 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,995 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California
| s13u74cr4 |
Dec 1 2024, 02:12 PM
Awesome, thanks! Had actually found the thread with those photos which look exactly like the ticket.
No problem sir if the fuel line length is more, don’t overthink it sir. This one I did on one our members. And if your original pump is not working, just use the 75/76 fuel pump. One In and One out. Much easier and simple. |
| JamesM |
Dec 1 2024, 07:10 PM
Caretaker of 914s - Master of Fuel Injection ![]() ![]() ![]() ![]() Group: Members Posts: 2,373 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
If you are already this far in, take the little extra time and move the pump up front.
Seriously, every time I have not relocated the pump I have wound up regretting it. |
| windforfun |
Dec 1 2024, 08:53 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,115 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None
If you are already this far in, take the little extra time and move the pump up front. Seriously, every time I have not relocated the pump I have wound up regretting it. Just a little extra time? Okay. In the 17 years that I've owned my "73 1.7, I've never had a problem with the FP in the back. Except for having to replace the FP because it leaked. (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) P.S. It's time for a new spell checker. |
| mlindner |
Dec 2 2024, 08:38 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,810 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest
| s13u74cr4 |
Dec 29 2024, 07:24 PM
Wasn’t planning on going this far until finding the reversed routing of the PO. Read of the dreaded vapor problem. The Porsche tech doc solution has been done. But brother is it tight in there. Not to mention every single clamp was oriented as if you sat in the engine and assembled.
| Garland |
Dec 29 2024, 10:35 PM
Restoration Fanatic ![]() ![]() ![]() Group: Members Posts: 1,438 Joined: 8-January 04 From: ......Michigan...... Member No.: 1,535 Region Association: Upper MidWest
| Jamie |
Dec 30 2024, 08:02 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,237 Joined: 13-October 04 From: Georgetown,KY Member No.: 2,939 Region Association: South East States
Neat install, but it appears you retain the original plastic fuel lines thru the tunnel, not safe practice. Go SS replacement for potential fire reduction (IMG:style_emoticons/default/WTF.gif) |
Lo-Fi Version | Time is now: 25th November 2026 - 06:34 PM |
