| slowrodent |
Dec 8 2024, 06:38 PM
Member ![]() ![]() Group: Members Posts: 245 Joined: 29-February 20 From: Tucson/Oro Valley Member No.: 23,981 Region Association: Southwest Region
Hi all... Was wondering what starting motor is the starter of choice for larger displacement engine swaps... Mine is/will be a 3.2 v6 and my current 914 starter is just not happy... Would like to hear what others have chosen... Thanks to all in advance..
Kevin (IMG:style_emoticons/default/santa_smiley.gif) |
| wndsrfr |
Dec 8 2024, 08:02 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,467 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region
Bosch SR68X...
| bkrantz |
Dec 8 2024, 08:14 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,782 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains
I got one of these, from Hi Torque. Overkill for my 2056 but it was the best option for me.
https://www.hitorque.com/Gear_Reduction_Sta..._p/imi-101n.htm Attached thumbnail(s) |
| ClayPerrine |
Dec 9 2024, 05:51 AM
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,568 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille
I got one of these, from Hi Torque. Overkill for my 2056 but it was the best option for me. https://www.hitorque.com/Gear_Reduction_Sta..._p/imi-101n.htm (IMG:style_emoticons/default/agree.gif) I run one of these on the 4.0L motor. It works great. I put an SR68x on the original six. It worked fine, but it was not the correct factory starter. I have replaced it with an SR19x starter. |
| VaccaRabite |
Dec 9 2024, 09:17 AM
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,915 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region
Highly dependent on the transmission you are using.
If a 901, using a 911 starter makes for a big power jump over the /4 starter. I have been using one of the IMI-155 starters that Pelican sells now for about a decade. Spins my 2.3 way faster then a stock 914 starter, and weighs a good bit less too. Zach |
| BillJ |
Dec 9 2024, 09:26 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,356 Joined: 4-March 13 From: charlotte, NC Member No.: 15,610 Region Association: None
That hi torque starter is what i use. Great unit
| slowrodent |
Dec 9 2024, 11:59 AM
oops..... as indicated, i should have specified stock 914-901 transmission...Kennedy adapter for engine-trans.
Lo-Fi Version | Time is now: 16th September 2026 - 05:12 AM |
