| DeWitt |
Mar 4 2025, 11:12 AM
Newbie ![]() Group: Members Posts: 13 Joined: 25-August 24 From: Lancaster County, PA Member No.: 28,309 Region Association: North East States |
I have a MaxJax lift in my hobby shop. When I had it installed (I went with pro installers), I had them put anchors in for two different widths. I've only ever used the narrow width, with my very narrow MG TD, but just recently I bought a very nice 1973 914 2.0 from a Porsche mechanic in Virginia. Today, I installed the post in the wide position, and it's just right for the 914! This photo is of the car in the highest lift position.
![]() I used the standard pads without the lift extensions, and added an ordinary hockey puck at each location to make sure the lift arms didn't touch the side skirts. I carefully aligned the pads and pucks under the four lift points - the round dimples with a hole in the center. Here are photos of front and rear points. ![]() ![]() I measured the distance between the front mounting bolt holes on the two posts, in case someone else is installing a MaxJax for 914 use. It was just shy of 119 inches in my setup. Here's a photo of that also, so you can see where I was measuring from. ![]() |
| VaccaRabite |
Mar 4 2025, 06:27 PM
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,917 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region
Hey DeWitt (IMG:style_emoticons/default/welcome.png)
I live down the road from you in Dallastown, and also have a 914 and a MaxJax. Though at the moment my car isn't on the lift, my Rabbit has been hogging it for the past year. Zach |
| Mikey914 |
Mar 4 2025, 07:44 PM
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,784 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None
I did twin Busch. As far as anchors go the engineering supports 10x the diameter of the anchor. If you are using .5" anchors, 5" works, if .625" they risk cracking. With a 914, you probably will not be having any issues, but here's some info-
https://www.engineeringexpress.com/wiki/spa...ncrete-anchors/ I know it says 12x, but all job specific engineering I've seen is 10x. -Mark |
| DeWitt |
Mar 5 2025, 09:27 AM
I did twin Busch. As far as anchors go the engineering supports 10x the diameter of the anchor. If you are using .5" anchors, 5" works, if .625" they risk cracking. With a 914, you probably will not be having any issues, but here's some info- https://www.engineeringexpress.com/wiki/spa...ncrete-anchors/ I know it says 12x, but all job specific engineering I've seen is 10x. -Mark Hi Mark, The installers used the recommended hardware from MaxJax. I believe they were M16 bolts, almost exactly equivalent in size to 5/8" UNC. There are 5 bolts in the base. I wasn't familiar with Twin Busch lifts, but I looked them up and they look really nice! I chose the MaxJax for two reasons: low ceiling clearance, and the ability to remove one or both posts when I need more open space. I chose pro installers so they could evaluate my 70-year-old concrete. I've been using it several years now, and all seems well. I just received a shipment from 914Rubber via an order on PMB Performance, all in good shape. Thanks! |
| DeWitt |
Mar 5 2025, 09:38 AM
Hey DeWitt (IMG:style_emoticons/default/welcome.png) I live down the road from you in Dallastown, and also have a 914 and a MaxJax. Though at the moment my car isn't on the lift, my Rabbit has been hogging it for the past year. Zach Thanks, Zach! Shoot me a message if you're ever in the Lancaster area. My shop is right downtown, and I'd love to show it off. |
| 914werke |
Mar 5 2025, 09:43 AM
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,757 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest
| worn |
Mar 5 2025, 08:03 PM
Winner of the Utah Twisted Joint Award ![]() ![]() ![]() ![]() Group: Members Posts: 3,652 Joined: 3-June 11 From: Madison, WI and North Bend WA Member No.: 13,152 Region Association: Upper MidWest
Hey DeWitt (IMG:style_emoticons/default/welcome.png) I live down the road from you in Dallastown, and also have a 914 and a MaxJax. Though at the moment my car isn't on the lift, my Rabbit has been hogging it for the past year. Zach (IMG:style_emoticons/default/welcome.png) I am surprised that no one has mentioned the matching yellow color scheme. Is the MG yellow as well? You may need to repaint the lift so as to be in synch with the lifted car. |
| North Coast Jim |
Mar 6 2025, 10:23 AM
Member ![]() ![]() Group: Members Posts: 348 Joined: 11-December 15 From: Northern Ohio Member No.: 19,450 Region Association: MidAtlantic Region
I have a MaxJax lift in my hobby shop. When I had it installed (I went with pro installers), I had them put anchors in for two different widths. I've only ever used the narrow width, with my very narrow MG TD, but just recently I bought a very nice 1973 914 2.0 from a Porsche mechanic in Virginia. Today, I installed the post in the wide position, and it's just right for the 914! This photo is of the car in the highest lift position. ![]() I used the standard pads without the lift extensions, and added an ordinary hockey puck at each location to make sure the lift arms didn't touch the side skirts. I carefully aligned the pads and pucks under the four lift points - the round dimples with a hole in the center. Here are photos of front and rear points. ![]() ![]() I measured the distance between the front mounting bolt holes on the two posts, in case someone else is installing a MaxJax for 914 use. It was just shy of 119 inches in my setup. Here's a photo of that also, so you can see where I was measuring from. ![]() Those locks are there for a safety reason. Better use them. |
| DeWitt |
Mar 7 2025, 03:52 PM
I chose the MaxJax for two reasons: low ceiling clearance, and the ability to remove one or both posts when I need more open space. How tall is your ceiling?Hi 914Werke, if you look at the photo of the car on the lift, you can see a gray steel beam , right at the top of the windshield. Clearance under that beam is exactly 8 feet. Before I had that beam installed, there was a post right at that spot, so the beam actually made the shop space useable. |
| DeWitt |
Mar 7 2025, 03:55 PM
Those locks are there for a safety reason. Better use them. Hi Jim, I definitely use the position locks, every time! In fact, I settle the car onto the locks to take pressure off the lift hydraulics, since the car can be up for days at a time while I'm working on it. |
| 76-914 |
Mar 7 2025, 04:02 PM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,967 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
Those donuts aren't designed for lifting. They're attach points the factory used on the assembly line. You can buy the slotted rubber discs on Amazon. There are several styles and IIRC one from MaxxJax. https://www.amazon.com/dp/B07RZQLW9G?ref=pp..._title&th=1
| Spoke |
Mar 7 2025, 04:05 PM
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,429 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None
Those locks are there for a safety reason. Better use them. Hi Jim, I definitely use the position locks, every time! In fact, I settle the car onto the locks to take pressure off the lift hydraulics, since the car can be up for days at a time while I'm working on it. (IMG:style_emoticons/default/agree.gif) @DeWitt The directions say the locks must be used. What I couldn't find in the instructions or online is how much torque to tighten the floor bolts with. I've been using 50FT-LB. |
| 914werke |
Mar 7 2025, 05:10 PM
Hi 914Werke, if you look at the photo of the car on the lift, you can see a gray steel beam , right at the top of the windshield. Clearance under that beam is exactly 8 feet. Before I had that beam installed, there was a post right at that spot, so the beam actually made the shop space useable. Ah Im in the process of a similar effort. My own home garage has a low ceiling as well which is why Ive looked at the Maxjack off & on I also have a center post that Im looking to remove in lue of a clear span by replacing the x2 11' beams with a single I beam (like yours?) or a U-channel added to the existing beams, moving the supports to outsides. (IMG:style_emoticons/default/smile.gif) |
| windforfun |
Mar 7 2025, 05:24 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,115 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None
Those donuts aren't designed for lifting. They're attach points the factory used on the assembly line. You can buy the slotted rubber discs on Amazon. There are several styles and IIRC one from MaxxJax. https://www.amazon.com/dp/B07RZQLW9G?ref=pp..._title&th=1 (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif) But... Everybody seems to use them for lifting. Thanks for the link. I just bought a set of the square pads. |
| Spoke |
Mar 8 2025, 02:22 PM
I can lift my 914 or 911 about 3 ft off the ground before they hit the garage door opener.
I did have a scare the other day with my 911 on the lift. Opened the door and it only opened partially then stopped. I realized I had the engine lid up and the opener arm hit the lid and stopped the opener. Luckily the arm hit the rubber part of the whale tail and did no damage. What a dipshit. |
| windforfun |
Mar 8 2025, 04:46 PM
I can lift my 914 or 911 about 3 ft off the ground before they hit the garage door opener. I did have a scare the other day with my 911 on the lift. Opened the door and it only opened partially then stopped. I realized I had the engine lid up and the opener arm hit the lid and stopped the opener. Luckily the arm hit the rubber part of the whale tail and did no damage. What a dipshit. When you replace your garage door opener you might want to consider a wall mounted unit. They attach to the torsion bar & are super easy to install. Chamberlain makes them & they're about $500. Scroll down to the third row in the link below. https://www.chamberlain.com/garage-door-ope...ge-door-openers (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/beerchug.gif) |
| mepstein |
Mar 8 2025, 04:49 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,919 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
Those locks are there for a safety reason. Better use them. Hi Jim, I definitely use the position locks, every time! In fact, I settle the car onto the locks to take pressure off the lift hydraulics, since the car can be up for days at a time while I'm working on it. (IMG:style_emoticons/default/agree.gif) @DeWitt The directions say the locks must be used. What I couldn't find in the instructions or online is how much torque to tighten the floor bolts with. I've been using 50FT-LB. I think 50 is right in the ballpark. I used epoxy anchors (per @mb911 suggestion) I’m very happy with the lift. |
| mb911 |
Mar 8 2025, 06:35 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,811 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest
Those locks are there for a safety reason. Better use them. Hi Jim, I definitely use the position locks, every time! In fact, I settle the car onto the locks to take pressure off the lift hydraulics, since the car can be up for days at a time while I'm working on it. (IMG:style_emoticons/default/agree.gif) @DeWitt The directions say the locks must be used. What I couldn't find in the instructions or online is how much torque to tighten the floor bolts with. I've been using 50FT-LB. I think 50 is right in the ballpark. I used epoxy anchors (per @mb911 suggestion) I’m very happy with the lift. Great lifts the epoxy fasteners had a spec I don’t recall as I got a 4 post lift with an air over hydraulic jack tray on it as a safer storage /work setup. Maxxjax was great though ![]() |
| windforfun |
Mar 8 2025, 06:57 PM
Wow!!!
(IMG:style_emoticons/default/drooley.gif) (IMG:style_emoticons/default/drooley.gif) (IMG:style_emoticons/default/drooley.gif) |
| Tonyooc |
Mar 10 2025, 07:02 PM
1974 2.0 ![]() ![]() ![]() Group: Members Posts: 1,003 Joined: 6-January 18 From: Fort Mill, SC Member No.: 21,763 Region Association: South East States
How tall is the lift? I only have 9' ceiling
Lo-Fi Version | Time is now: 24th September 2026 - 06:31 PM |
