sixaddict |
Senior Member ![]() ![]() ![]() Group: Members Posts: 965 Joined: 22-January 09 From: Panama City Beach, FL Member No.: 9,961 Region Association: South East States ![]() ![]() |
Looking for new pressure plate……one listed for 914-6 is also shown as part of “kit” for 4 cylinder cars so not sufficient for HP of engine.
Anyone able to give me part number for what I need without going exotic. Thanks |
Tom1394racing |
Member ![]() ![]() Group: Members Posts: 466 Joined: 25-August 07 From: CT Member No.: 8,039 Region Association: North East States ![]() ![]() |
I went with a Kennedy Engineering clutch kit for my 3.2 conversion.
Tom1394racing |
Please delete.....duplicate post
Steve |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,904 Joined: 14-June 03 From: Laguna Niguel, CA Member No.: 822 Region Association: Southern California ![]() ![]() |
Looking for new pressure plate……one listed for 914-6 is also shown as part of “kit” for 4 cylinder cars so not sufficient for HP of engine. Anyone able to give me part number for what I need without going exotic. Thanks 2.0 four is the same for 2.0 six. I put a 2.0 six flywheel on my 2.7 and used the same clutch. No slippage or issues. Nine bolt flywheel for 3.0 and above requires a KEP setup. |
Superhawk996 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,270 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch ![]() ![]() |
Clutches and pressure plates don’t care about horsepower. Torque is what matters
914/6 2.0L was about 120 lb-ft 914/4 2.0L was about 116 lb-ft This is why the /6 and /4 share the “kit” Sachs and others publish the torque specs of their hardware if you’re doing something outrageous. Chart below is for standard clutch materials. Other friction and pressure plates available if you need more capacity. ![]() Max torque: 250Nm =184.391 lb-ft |
sixaddict |
Thanks for input.
davep |
914 Historian ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,303 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada ![]() ![]() |
Originally the 914/4 friction disc had 4 springs, and 914/6 had six springs. but since the specs were so similar it made sense to just stock a 914/6 disc and PP to use with both and some 911's.
sixaddict |
Makes sense
porschetub |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,904 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None ![]() |
Lo-Fi Version | Time is now: 11th August 2025 - 02:04 AM |
