9146-racer |
Newbie ![]() Group: Members Posts: 29 Joined: 4-September 20 From: hampshire uk Member No.: 24,659 Region Association: None ![]() |
Hi All.
Does anyone know where in the uk I can buy one? or failing that what are the dimensions ? cheers Ian |
jim_hoyland |
Get that VIN ? ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,869 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California ![]() ![]() |
9146-racer |
Not the washer, I want the of centre insulator that bolts to the bulkhead and the wiper motor. |
Luke M |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,417 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States ![]() ![]() |
jim_hoyland |
Are two required ? or just one ?
sixaddict |
Senior Member ![]() ![]() ![]() Group: Members Posts: 969 Joined: 22-January 09 From: Panama City Beach, FL Member No.: 9,961 Region Association: South East States ![]() ![]() |
Don’t consider myself “expert”…..but I disassembled one and have one currently….only one per rack based on that experience…$2 from what I am seeing.
mate914 |
Matt ![]() ![]() ![]() Group: Members Posts: 889 Joined: 27-February 09 From: Eagles mere, PA Member No.: 10,102 Region Association: North East States ![]() ![]() |
Not the washer, I want the of centre insulator that bolts to the bulkhead and the wiper motor. I think its the same part used in other P cars. Rubber bushing with a stud on each end. Right? I did this same job about two years ago. Lots of vendors have them. Matt |
sixnotfour |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,934 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains ![]() ![]() ![]() |
Attached image(s) ![]() |
Mikey914 |
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,772 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None ![]() ![]() |
Not the washer, I want the of centre insulator that bolts to the bulkhead and the wiper motor. I think its the same part used in other P cars. Rubber bushing with a stud on each end. Right? I did this same job about two years ago. Lots of vendors have them. Matt Wrong. Lots of companies make isolators, but the correct part has an offset. We make the one with the offset. The fuel pump mount ones are not and are inexpensive as they are commercially available. There is a reason we made these. You can maybe flex one enough to get it in, but I'm sure you will have a premature failure as they aren't designed to hold an offset load with additional flexing. https://914rubber.com/search/?q=offset+isolator |
Gordon.Hewitt |
Newbie ![]() Group: Members Posts: 1 Joined: 2-July 25 From: United Kingdom Member No.: 28,868 Region Association: England ![]() |
If you are still looking, I have a spare in the UK.
Lo-Fi Version | Time is now: 1st September 2025 - 04:13 AM |
