PaIsa |
Member ![]() ![]() Group: Members Posts: 126 Joined: 13-June 24 From: Quebec, Canada Member No.: 28,180 Region Association: Canada ![]() |
I am still dealing with a small leak at my speedo gear at the back of the transmission.
I currently have the original bushing with only 1 o-ring and I have available the update version with 2 o-rings but I need to replace the seal in this one. The problem I have is to get the seal to go in the bushing. It is a very tight fit and I already destroyed I seal trying. What is the method to get this in. Freeze the seal? Heat the bushing? Combination of both? Something else? ![]() |
bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() Group: Members Posts: 4,970 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
Use a long 10mm bolt, washer and nut to act as an install tool
PaIsa |
Nogoodwithusernames |
Member ![]() ![]() Group: Members Posts: 289 Joined: 31-May 16 From: Sutter, CA Member No.: 20,051 Region Association: None ![]() |
If you don't have a press you can fake it with a bench vise or drill press. Some lube on the seal is always good too.
914sgofast2 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 723 Joined: 10-May 13 From: El Dorado Hills, CA Member No.: 15,855 Region Association: None ![]() |
Use some silicon grease on the seal. It can be found on Amazon. Silicon grease makes tight seals slide right in.
bdstone914 |
How i do it.
And some lube on the bore and seal Attached thumbnail(s) ![]() |
Lo-Fi Version | Time is now: 3rd June 2025 - 06:56 AM |
