Jgilliam914 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,358 Joined: 30-July 12 From: Iowa / Florida Member No.: 14,732 Region Association: Upper MidWest ![]() |
friethmiller |
Senior Member ![]() ![]() ![]() Group: Members Posts: 941 Joined: 10-February 19 From: Austin, TX Member No.: 22,863 Region Association: Southwest Region ![]() ![]() |
what webers are these? they have sat 10 years or longer and figure I should rebuild these. I have combed them over and have yet to find anything. Also where does the engine blower bolt to? Ive flipped this thing all around and yet to see where it bolts to. These look a lot like my 44IDFs. Might be 40s, not sure. Congrats on having a manual choke. I wish I had that. You can rig up a cable and make those cold starts a breeze. (IMG:style_emoticons/default/smilie_pokal.gif) |
barefoot |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,410 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States ![]() ![]() |
Jgilliam914 |
For the rear heater assist blower, there were 2 mounting locations, not sure what years utilized: Just under the rear fuze panel is a bracket that i use to mount a fuel filter. ![]() A bracket that bolts to the engine fan housing (not my motor) ![]() ah this make sense now. I had the mounting bracket on backwards. (IMG:style_emoticons/default/dry.gif) flipped it around and hooked up correctly. |
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,196 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
The fan-shroud-mounted bracket was used on the 70-72 cars. The pedestal on the engine shelf was used in 73-76 cars.
--DD |
Lo-Fi Version | Time is now: 7th July 2025 - 05:12 AM |
