> Question on pre “bent” brake lines
sixaddict
post Jul 14 2025, 07:23 AM
Stoddard has pre bent brake line kit in galvanized or “ green”.
If you want “correct” assuming you stay with galvanized.
Comments?
bdstone914
post Jul 14 2025, 07:34 AM
bdstone914
QUOTE(sixaddict @ Jul 14 2025, 06:23 AM) *
Comments?
They are probably carrying the PMB lines. Compare the price. Yes green was not original
Cairo94507
post Jul 14 2025, 10:29 AM
Michael
We did pre-bent, green lines in my car. No problems and fitment was very good. Sourced through PMB. (IMG:style_emoticons/default/beerchug.gif)
Jack Standz
post Jul 14 2025, 12:49 PM
If you go with stainless steel(availablefrom PMB), understand that these lines are harder.
Put a set on a few weeks ago and had to really tighten them before they stopped leaking.
flyer86d
post Jul 14 2025, 01:00 PM
I make my own. When I owned my shop I’m Vermont, replacing rusty brake lines was a weekly job. You can buy new fittings with the material of your for tubing. You just need a tubing bender, a tubing cutter, and bubble flair tool for Porsches and other european cars.
Charlie
fixer34
post Jul 14 2025, 05:39 PM
QUOTE(Jack Standz @ Jul 14 2025, 01:49 PM) *
Unless you plan on racing or Very heavy braking, the standard steel lines are just fine
dtmehall
post Jul 14 2025, 06:27 PM
Aren't the flexible lines the 'weak link' anyway?
Jack Standz
post Jul 14 2025, 06:45 PM
QUOTE(fixer34 @ Jul 15 2025, 06:39 AM) *
The standard tin coated steel lines work fine.
But, the stainless ones do not corrode over time (especially with hygroscopic brake fluids), look cool and are less expensive than the green ones.
sbsix
post Jul 14 2025, 07:21 PM
only the lead dog enjoys a change in scenery...
Years ago I bought several front brake lines from Stoddard that were green coated. I learned that they were indeed NOS green coated.
bkrantz
post Jul 14 2025, 07:27 PM
QUOTE(Jack Standz @ Jul 14 2025, 12:49 PM) *
Same here. And it took REALLY torquing the flare nut wrench, as advised by PMB. Even then I had a couple of junctions that still weeped. PMB sent me some special sealant for those.
sixaddict
post Jul 14 2025, 08:39 PM
Thanks all
2 User(s) are reading this topic (1 Guests and 0 Anonymous Users)
1 Members: Jack Standz
- Lo-Fi Version Time is now: 15th July 2025 - 08:52 AM
