Jgilliam914 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,362 Joined: 30-July 12 From: Iowa / Florida Member No.: 14,732 Region Association: Upper MidWest ![]() |
Bought a Gemo and went to install it. and slides about 20" in the tube and becomes stuck. I blew out the tube lubed it and again no difference. In my frustration I decided to put in a cable I have had for over 40 years. Yep you guessed it. Slipped right in without issues. Is there a fix before I go buy a OEM? The 40 year old one isn't usable long term
bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,048 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
Bought a Gemo and went to install it. and slides about 20" in the tube and becomes stuck. I blew out the tube lubed it and again no difference. In my frustration I decided to put in a cable I have had for over 40 years. Yep you guessed it. Slipped right in without issues. Is there a fix before I go buy a OEM? The 40 year old one isn't usable long term I have heard of cables that use larger wire strands and have more friction. Ompare the Gemo to the old one. Porsche he may have the same cable as Gemo. |
sixnotfour |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,912 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains ![]() ![]() ![]() |
A recent same experience..
http://www.914world.com/bbs2/index.php?s=&...t&p=3198090 |
Jgilliam914 |
I did a search prior to asking a similar question and didn't see this. I will pull the old and check it out. by the naked eye it looked the same but I didn't put a micrometer on it to check it. I know the tolerences are tight and expected the tube to be full of rust but when the OEM went it smoothly I knew it was a manufacturers issue |
Jgilliam914 |
I put my micrometer to the OEM and Gemo and found .3mm difference. A little emory cloth and she slipped in just fine!! Thanks for the information! That's what I love about you peeps. Someone here has had the same issues and a remedy can usually be found!!
porschetub |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,887 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None ![]() |
I put my micrometer to the OEM and Gemo and found .3mm difference. A little emory cloth and she slipped in just fine!! Thanks for the information! That's what I love about you peeps. Someone here has had the same issues and a remedy can usually be found!! I fitted the same cable and was fine but tight to get in,,however the clutch cable of the brand was a right PITA ,refitted the original low mileage one and sorted ,was pretty clear they have fitment issues. Appears to have been a lot of chat about that brand (IMG:style_emoticons/default/confused24.gif) ?. |
IronHillRestorations |
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,835 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None ![]() ![]() |
I’m going to bet there’s extra mass on the end, where it’s swayed to the cable.
Dlee6205 |
Member ![]() ![]() Group: Members Posts: 61 Joined: 9-December 22 From: Burnsville, NC Member No.: 27,017 Region Association: South East States ![]() |
I’m going to bet there’s extra mass on the end, where it’s swayed to the cable. (IMG:style_emoticons/default/agree.gif) I've experienced this several times. Grinding down or rounding off the swaged end slightly has worked. |
Lo-Fi Version | Time is now: 19th July 2025 - 02:10 AM |
