Osnabruck914 |
Member ![]() ![]() Group: Members Posts: 154 Joined: 19-December 22 From: United States Member No.: 27,038 Region Association: South East States ![]() |
My car came with this ridiculous and heavy (22 lbs) tow bar assembly mounted under the nose. I put up with it for over ten years, hitting innumerable curbs, driveway dips, and parking space stops and today I finally removed it.
My question now is, how do you safely pull a 914 from the front onto the bed of a flatbed truck (which were the only instances I ever used the tow bar for)? Where should a tow guy attach his chains/straps underneath safely, where nothing will break, to winch the car forward onto the truck? Thank you. Osnabruck914 ![]() |
DRPHIL914 |
Dr. Phil ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,840 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States ![]() ![]() |
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,994 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
Grab an axle strap at harbor freight, amazon, etc and throw it in the trunk. Loop it over the reinforcement strut on the a-arm and the tow driver can hook his chain to it.
Attached thumbnail(s) ![]() |
Krieger |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,815 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None ![]() ![]() |
That looks like a lot more than 22lbs
Literati914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,046 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region ![]() |
Grab an axle strap at harbor freight, amazon, etc and throw it in the trunk. Loop it over the reinforcement strut on the a-arm and the tow driver can hook his chain to it. Another great idea!! Hadn't thought of this either! (IMG:style_emoticons/default/beer.gif) |
mepstein |
Grab an axle strap at harbor freight, amazon, etc and throw it in the trunk. Loop it over the reinforcement strut on the a-arm and the tow driver can hook his chain to it. Another great idea!! Hadn't thought of this either! (IMG:style_emoticons/default/beer.gif) I've done it dozens of times to pull a car onto my trailer with the winch. |
Osnabruck914 |
Thanks Mepstein. That solves my problem!
Osnabruck914 |
bkrantz |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,467 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains ![]() ![]() |
If you are really paranoid, get some of these.
https://tangerineracing.com/shop/ols/produc...front-tie-downs |
porschetub |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,896 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None ![]() |
If you are really paranoid, get some of these. https://tangerineracing.com/shop/ols/produc...front-tie-downs Is the tow hook underneath rubbish ,don't know cause never been towed... Cheers. |
mepstein |
If you are really paranoid, get some of these. https://tangerineracing.com/shop/ols/produc...front-tie-downs Is the tow hook underneath rubbish ,don't know cause never been towed... Cheers. Usually a rollback will have a bunch of extras to make it work but the large hook on the end of the cable won't always fit the tow hook. There isn't a lot of clearance between the loop and the floor pan. It also can scratch the paint. The $10 strap solves the issue 99% of the time. Sometimes deep spoilers are an issue. |
DRPHIL914 |
If you are really paranoid, get some of these. https://tangerineracing.com/shop/ols/produc...front-tie-downs Is the tow hook underneath rubbish ,don't know cause never been towed... Cheers. Usually a rollback will have a bunch of extras to make it work but the large hook on the end of the cable won't always fit the tow hook. There isn't a lot of clearance between the loop and the floor pan. It also can scratch the paint. The $10 strap solves the issue 99% of the time. Sometimes deep spoilers are an issue. Thats a great idea, use the strap for that center tow loop just to pull up onto the trailer with the come-along winch, i did that before i put the tow bar for flat towing on, i guess my earlier comment was because i was thinking about him doing this on a regular basis but if he's not going to flat tow and just pulling onto a trailer once and awhile definitely doesn't need the flat tow bar. |
Osnabruck914 |
mepstein,
Got myself today a couple of the Harbor Freight axle straps you recommended. Now just to be clear, is the best attachment point on the a-arm(s) where I circled in the attached pic? Osnabruck914 ![]() |
mepstein |
mepstein, Got myself today a couple of the Harbor Freight axle straps you recommended. Now just to be clear, is the best attachment point on the a-arm(s) where I circled in the attached pic? Osnabruck914 ![]() Yes, that portion of the a-arm is more than strong enough to pull your car up the incline of a rollback. |
Lo-Fi Version | Time is now: 1st August 2025 - 08:40 AM |
