> Two questions, front bumper and steering wheel
914ltd
post Aug 19 2025, 02:52 PM
The first one is almost dumb, OK, dumb. On the 1973 and 1974 front bumper. These blocks are located behind the front tits. Which way does the fat part of the rubber block set, up or down? I believe I have been installing them fat up but I don't remember if I researched it or assumed?
Second Q, I have a '74 with the foam rubber stock steering wheel. As many do, the foam part turns on the steel ring. Has someone injected glue inside the foam to fix this? Any other ways to remedy?
Thanks, Brad
friethmiller
post Aug 19 2025, 04:24 PM
QUOTE(914ltd @ Aug 19 2025, 03:52 PM) *
No clue if these were ever messed with but I just pulled out my bumper this past weekend to be restored. Looks like fat part "up".
914ltd
post Aug 20 2025, 06:19 AM
QUOTE(friethmiller @ Aug 19 2025, 02:24 PM) *
OK, Thanks for the reply. Brad
porschetub
post Aug 20 2025, 11:55 PM
QUOTE(914ltd @ Aug 20 2025, 08:52 AM) *
Thanks, Brad
Tried the glue trick on a steering wheel , I got most of it stuck ,not long later it came away further each side of the reglued area ,was super careful but to little result sadly.
Someone on here may have a better solution ? ,cheers .
bdstone914
post Aug 21 2025, 04:14 AM
bdstone914
@914LTD
I friend told me to use epoxy diluted with acetone and injection with a hypodyermic needle.
And I never noticed they had a taper. Learned something new after decades of taking cars apart.
bdstone914
post Aug 21 2025, 05:44 AM
bdstone914
@porschetub
[/quote]
What kind of glue did you use?
914Sixer
post Aug 21 2025, 05:45 AM
Thinking the difference in pad caused by years of being compressed from being mounted.
- Lo-Fi Version Time is now: 21st August 2025 - 10:31 AM
