Mike1981 |
Member ![]() ![]() Group: Members Posts: 257 Joined: 21-July 14 From: Phoenix Member No.: 17,663 Region Association: Southern California ![]() |
Can anyone ID each of these relays?
I used the search and google and cant find any similar diagrams.. Thank you Attached thumbnail(s) ![]() |
914Sixer |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,226 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region ![]() ![]() |
Turn signal post is mounted in dash frame NOT on fuse block board for 70-71. Round are multi purpose and square is head light relay. Turn signal relay is SQUARE with FOUR blades. Picture is late model solid state
dr914@autoatlanta.com |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,201 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None ![]() |
Mike1981 |
Thanks for the clarification
could the turn signal relay be one of these I found under the dash? Attached thumbnail(s) ![]() |
Lo-Fi Version | Time is now: 22nd August 2025 - 12:26 PM |
