jamlip |
Member ![]() ![]() Group: Members Posts: 51 Joined: 8-November 21 From: Palm Springs CA Member No.: 26,060 Region Association: Southern California ![]() |
Looking for the connector for this multi-pin plug on the relay board.
Don't need whole harness - just the plug (IMG:style_emoticons/default/smile.gif) (IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-26060-1756109434.1.jpeg) |
TheCabinetmaker |
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,350 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 ![]() |
New at Bughaus
Puebloswatcop |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,662 Joined: 27-December 14 From: Mineola, Texas Member No.: 18,258 Region Association: Southwest Region ![]() |
JeffBowlsby |
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,024 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None ![]() ![]() |
There are four multi-pin connectors to the relay board. 3, 4, 12 & 14 pins.
Which one do you need? |
jamlip |
One of the more experienced members suggested I ditch the whole board (I'm doing an engine conversion). Thanks anyway!
IronHillRestorations |
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,857 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None ![]() ![]() |
If you’re keeping the relay board, you need the twelve pin female connector; part number 91161212204. If you’re going to delete the relay board then you need the fourteen pin male connector part number 91161211305.
If you’re doing an engine swap with an air cooled 911 engine, I can make a custom engine wiring harness. I’ve been producing them for over twenty years. They are plug and play, and look like a factory part. PM me if I can help. |
Lo-Fi Version | Time is now: 29th August 2025 - 07:10 AM |
