echocanyons |
Advanced Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,112 Joined: 24-December 02 From: Bay Area, CA Member No.: 7 Region Association: Central California ![]() ![]() ![]() |
If the speedo cable is disconnected at the trans will all of the trans oil spill out or is it ok to drive ?
Cannot seem to reconnect the speedo cable because it was dragged under the car for. Period of time |
fixer34 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,337 Joined: 16-September 14 From: Chicago area Member No.: 17,908 Region Association: Upper MidWest ![]() ![]() |
If the speedo cable is disconnected at the trans will all of the trans oil spill out or is it ok to drive ? Cannot seem to reconnect the speedo cable because it was dragged under the car for. Period of time If you just disconnect the speedo cable end and don't remove the angle gear assembly, there isn't any problem. but I would put something around the open end to make sure dirt doesn't get in. The gears inside will still be turning if you drive it. Or if the speedo cable is shot from dragging and needs to be replaced anyway, just hack the trans end off a couple inches from the end and leave that connected. It is a hardened cable and sheath so you need a good hacksaw or sharp chisel |
echocanyons |
Thank you!
We are making the trek back from the RRC |
barefoot |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,429 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States ![]() ![]() |
You can remove the speedo angle drive (with the big nut) without oil leakage.
If you remove the big aluminum bit then oil will leak. i just had to rebuild mine. |
Lo-Fi Version | Time is now: 14th September 2025 - 11:49 PM |
